  1. To create, duplicate, delete, and send commands to a schedule, use the command namespace as described below
  1. To update a plugin's props on a schedule, call mySchedule.replacePluginPropsOnServer(newPropsDict) rather than try to update them on the local schedule
Under construction
absoluteDate datetime.datetime / None
absoluteDateTime datetime.datetime / None
absoluteTime datetime.datetime / None
autoDelete boolean Yes true if Indigo should automatically delete this schedule after the next execution, otherwise false
configured boolean Yes true if the schedule has been fully configured, otherwise false
dateType indigo.kDateType / None
description string Yes description of the schedule
enabled boolean Yes
folderId integer No unique ID of the folder this schedule is in
globalProps dictionary No
id integer No a unique id of the schedule, assigned on creation by IndigoServer
name string Yes the unique name of the schedule - no two schedules can have the same name
nextExecution datetime.datetime / None
pluginProps dictionary No
remoteDisplay boolean Yes true if remote clients should display the schedule, otherwise false (does not affect the Indigo client UI
sharedProps dictionary No
sunDelta integer
suppressLogging boolean Yes true if Indigo should skip logging the schedule's execution in the event log, otherwise false
timeType indigo.kTimeType
upload boolean Yes true if IndigoServer should attempt to upload this schedule to the interface
indigo.schedule.delete(123)
Enable
schedule_data No object data to be passed to the schedule before it is executed
Move to Folder
Move to Folder
  • /www/perceptive/wiki/data/attic/indigo_2025.1_documentation/schedule_class.1771468183.txt.gz
  • Last modified: 2026/02/19 02:29
