To create, duplicate, delete, and send commands to a schedule, use the command namespace as described below
To modify an object's definition, get a copy of the schedule, make the necessary changes, then call mySchedule.replaceOnServer(newPropsDict)
To update a plugin's props on a schedule, call mySchedule.replacePluginPropsOnServer(newPropsDict) rather than try to update them on the local schedule
Under construction
absoluteDate | datetime.datetime / None | | |
absoluteDateTime | datetime.datetime / None | | |
absoluteTime | datetime.datetime / None | | |
dateType | indigo.kDateType / None | | |
description | string | Yes | description of the schedule |
enabled | boolean | Yes | true if the schedule is enabled, otherwise false (Indigo will not execute the schedule if false |
nextExecution | datetime.datetime / None | No | The date and time of the schedule's next execution |
remoteDisplay | boolean | Yes | true if remote clients should display the schedule, otherwise false (does not affect the Indigo client UI |
sunDelta | integer | Yes | The number of seconds before (negative) or after (positive) sunrise or sunset when the schedule should be executed (zero if no offset) |
suppressLogging | boolean | Yes | true if Indigo should skip logging the schedule's execution in the event log, otherwise false |
timeType | indigo.kTimeType | | |
Commands (indigo.schedule.*)
indigo.schedule.delete(123)
| Parameters |
| Parameters |
Enable
| Parameters |
| Parameters |
schedule_data | No | object | data to be passed to the schedule before it is executed |
| Parameters |
Move to Folder
| Parameters | |
Move to Folder
| Parameters |
