Schedules
Schedule Base Class
- To create, duplicate, delete, and send commands to a schedule, use the command namespace as described below
- To modify an object's definition, get a copy of the schedule, make the necessary changes, then call
mySchedule.replaceOnServer(newPropsDict)
- To update a plugin's props on a schedule, call
mySchedule.replacePluginPropsOnServer(newPropsDict)rather than try to update them on the local schedule
Under construction
absoluteDate | datetime.datetime / None | Yes | The absolute date of the next schedule execution with 00:00:00 as the base time |
absoluteDateTime | datetime.datetime / None | Yes | The absolute date and time of the next schedule execution |
absoluteTime | datetime.datetime / None | Yes | The absolute time of the next schedule execution with 2000-01-01 as the base date |
dateType | indigo.kDateType / None | Describes the “type” of date/time options for the schedule [Absolute / EveryDay / DaysOfWeek / DaysOfMonth] | |
description | string | Yes | description of the schedule |
enabled | boolean | Yes | true if the schedule is enabled, otherwise false (Indigo will not execute the schedule if false) |
nextExecution | datetime.datetime / None | No | The date and time of the schedule's next execution |
pluginProps | dictionary | No | pluginProps will return an empty dict because plugins cannot currently create custom schedules |
remoteDisplay | boolean | Yes | true if remote clients should display the schedule, otherwise false (does not affect the Indigo client UI |
sunDelta | integer | Yes | The number of seconds before (negative) or after (positive) sunrise or sunset when the schedule should be executed (zero if no offset) |
suppressLogging | boolean | Yes | true if Indigo should skip logging the schedule's execution in the event log, otherwise false |
timeType | indigo.kTimeType | Yes | Absolute / Sunrise / Sunset / Countdown depending on the date and time options selected |
Commands (indigo.schedule.*)
indigo.schedule.delete(123) |
| Parameters | |||
indigo.schedule.duplicate(123, duplicateName="my duplicate name") |
| Parameters | |||
Enable
indigo.schedule.enable(123, value=True, delay=0, duration=0) |
| Parameters | |||
indigo.schedule.execute(123, ignoreConditions=False, schedule_data=None) |
| Parameters | |||
schedule_data | No | object | an indigo.Dict to be passed to the schedule before it is executed |
- “server” if it's something generated from the server itself (schedule execution, built-in trigger, etc)
- “python” if it's something that comes through IPH that doesn't already have a source attached (scripts, plugins)
- “api-http” if it came from the HTTP API and there wasn't already an included “source”
- “api-websocket” if it came from the websocket API and there wasn't already an included “source”
For example, if you
my_dict = indigo.Dict() my_dict["foo"] = "bar" indigo.schedule.execute(324976872, schedule_data=my_dict)
indigo.schedule.getDependencies(123) |
| Parameters | |||
Move to Folder
indigo.schedule.moveToFolder(123, value=) |
| Parameters | ||||
indigo.schedule.removeDelayedActions(123) |
| Parameters | |||
