Indigo Object Model Reference
About this Reference
| Term | Meaning |
Introduction
For Scripters and Developers:
For Developers:
| Devices | ||
| Schedule | ||
| Triggers | ||
DeviceStateChangeTrigger (indigo.DeviceStateChangeTrigger) | indigo.devStateChange.* | manipulate a device state change trigger |
PluginEventTrigger (indigo.PluginEventTrigger) | indigo.pluginEvent.* | manipulate a trigger defined by a plugin event |
| Action Groups | ||
| Variables | ||
| General Commands | ||
IOM Class Hierarchy
Indigo specific data types
- keys cannot contain spaces.
The behavior that items are always retrieved as values (not references) can lead to some unexpected results when compared to python dicts and lists, especially when multiple levels of container nesting is being used. What this means is that you can set items and append to items, but the items returned from the get iterators are always new copies of the values and not references. For example, consider:
print(str(a))
python_dict = dict(my_indigo_dict) python_list = list(my_indigo_list)
Built-in objects
| Object | Description |
Object Events
# do your stuff here - make the network connection if necessary, write the data, etc.
Lower-level Events
if cmd.secCodeId == 6:
Iterating Object Lists
for dev in indigo.devices:
# do stuff with dev here
| Filter | Description |
| props.SupportsOnState | return only devices that support an ON state property |
Triggers also have filters:
for var in indigo.variables:
# all variables
Common Python Exceptions
| Possible Exceptions | |
Classes and Commands
# first, let's get an indigo.DimmerDevice like a LampLinc >>> dev = indigo.devices[238621905] >>> dev.__class__ <class 'indigo.DimmerDevice'> >>> hasattr(dev,'onState') True >>> dir(dev) ['__class__', '__delattr__', '__dict__', '__doc__', '__getattribute__', '__hash__', '__init__', '__module__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__str__', '__weakref__', 'address', 'brightness', 'buttonGroupCount', 'description', 'deviceTypeId', 'enabled', 'folderId', 'globalProps', 'id', 'lastChanged', 'model', 'name', 'onState', 'pluginId', 'pluginProps', 'protocol', 'refreshFromServer', 'remoteDisplay', 'replaceOnServer', 'replacePluginPropsOnServer', 'states', 'supportsAllLightsOnOff', 'supportsAllOff', 'supportsStatusRequest', 'updateStateOnServer', 'version'] # Next, an indigo.ThermostatDevice >>> thermo = indigo.devices[171495708] >>> thermo.__class__ <class 'indigo.ThermostatDevice'> >>> dir(thermo) ['__class__', '__delattr__', '__dict__', '__doc__', '__getattribute__', '__hash__', '__init__', '__module__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__str__', '__weakref__', 'address', 'buttonGroupCount', 'coolIsOn', 'coolSetpoint', 'description', 'deviceTypeId', 'enabled', 'fanIsOn', 'fanMode', 'folderId', 'globalProps', 'heatIsOn', 'heatSetpoint', 'humidities', 'humiditySensorCount', 'hvacMode', 'id', 'lastChanged', 'model', 'name', 'pluginId', 'pluginProps', 'protocol', 'refreshFromServer', 'remoteDisplay', 'replaceOnServer', 'replacePluginPropsOnServer', 'states', 'supportsAllLightsOnOff', 'supportsAllOff', 'supportsStatusRequest', 'temperatureSensorCount', 'temperatures', 'updateStateOnServer', 'version'] # Here's a plugin defined device >>> tunes = indigo.devices["Whole House iTunes"] # notice that it only shows the Device base class >>> tunes.__class__ <class 'indigo.Device'> >>> dir(tunes) ['__class__', '__delattr__', '__dict__', '__doc__', '__getattribute__', '__hash__', '__init__', '__module__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__str__', '__weakref__', 'address', 'buttonGroupCount', 'description', 'deviceTypeId', 'enabled', 'folderId', 'globalProps', 'id', 'lastChanged', 'model', 'name', 'pluginId', 'pluginProps', 'protocol', 'refreshFromServer', 'remoteDisplay', 'replaceOnServer', 'replacePluginPropsOnServer', 'states', 'supportsAllLightsOnOff', 'supportsAllOff', 'supportsStatusRequest', 'updateStateOnServer', 'version'] # You can use the deviceTypeId attribute to get the plugin's defined type >>> tunes.deviceTypeId u'mediaserver'
Object Dictionaries
>>> dev = indigo.devices[123]
address :
batteryLevel : None
buttonGroupCount : 0
configured : True
description :
<'indigo.Device'>
>>> dev_dict = dict(dev)
<class 'dict'>
- Device classes
- Trigger classes
- Schedule class
not yet implemented
- Action classes
- Action Group class
- Variable class
- Folder class
Utility Classes and Functions
Classes
| Name | Base | Description |
IndigoJSONEncoder | JSONEncoder | Use this encoder class if you are encoding a python date, time, or datetime class into a JSON string. Very useful if you attempt to encode a device dictionary into JSON (json.dumps(dict(mydevice), cls=indigo.utils.IndigoJSONEncoder)) |
Functions
Return Static File
| Parameters | |||
"status": 404,
"headers": {
"Content-Type": "text/html"
"file_path": "/Library/Application Support/Perceptive Automation/Indigo 2025.2/Plugins/Example HTTP Responder.indigoPlugin/Contents/Resources/static/html/static_404.html"
Validate Email Address
indigo.utils.validate_email_address("[email protected]")
| Parameters | |||
Boolean Functions
There are two functions available that will help scripters and developers in converting and using strings that represent boolean values, but are not True and False.
The first is str_to_bool(val: str). It will convert the string passed in to a boolean value and return it. We use the following map and it's reverse to do the mapping:
BOOL_MAP_TRUE: dict[str, str] = {
"y": "n",
"yes": "no",
"t": "f",
"true": "false",
"on": "off",
"1": "0",
"open": "closed",
"locked": "unlocked",
indigo.utils.str_to_bool("closed")
| Parameters | |||
val | Yes | string | a string that represents a boolean value as mapped above |
Returns True for true values, False for values that are false, and will raise an indigo.utils.ValueError if the input can't be successfully converted.
The second is reverse_bool_str_value(val: str). It will return the string that represents the opposite boolean value using the map above.
indigo.utils.reverse_bool_str_value("closed")
| Parameters | |||
val | Yes | string | a string that represents a boolean value for which we want the opposite string value |
This example returns open since that's the opposite of closed. It will raise an indigo.utils.ValueError if the input can't be successfully found.
