Indigo Server Plugin Tutorial
Note most of the code examples below are calling methods on the object self. In this context, self is meant to be the Plugin instance as defined inside the plugin.py file. To execute the sample code outside of Plugin instance methods, use the indigo.activePlugin object instead.
Important: For simplicity, some of the samples below specify objects based on name (indigo.devices[“office desk lamp”]). However, the preferred lookup mechanism is to use the object's numeric ID (indigo.devices[12345678]), which can be retrieved by control-clicking on the object name in Indigo's Main Window. By using the numeric ID you ensure the object will be found even if its name is changed.
Included in the SDK are examples that create plugin based relay, dimmer, thermostat, sensor, speed control, sprinkler, energy meter and custom devices. Also included is an example showing basic Indigo database traversal, how to catch low-level X10/INSTEON messages, and how to create an Indigo telnet server using the python twisted framework. The following table lists the Indigo Plugin SDK examples that were available at the time Indigo 2025.2 shipped.
SDK Plugin task Plugin that illustrates an approach
Broadcast Plugin Information to Listeners Example Custom Broadcaster
Subscribe to Plugin Information Broadcast Example Custom Subscriber
Walk Through the Indigo Database Example Database Traverse
Non-native Device Type Example Device - Custom
Energy Meter Device Type Example Device - Energy Meter
Device Factory Device Type Example Device - Factory
Switch / Relay / Dimmer Device Type Example Device - Relay and Dimmer
Sensor Device Type (Water, Motion, Light, Humidity) Example Device - Sensor
Speed Control Device Type (Fan) Example Device - Speed Control
Sprinkler Device Type Example Device - Sprinkler
Thermostat Device Type Example Device - Thermostat
Interact with the Indigo Server Using HTTP Client / Server Example HTTP Responder
Listen for Insteon and/or X-10 Traffic Example INSTEON:X10 Listener
Listen for Indigo Variable Change Notifications Example Variable Change Subscriber
Listen for Z-Wave Traffic Example Z-Wave Listener
Parsing JSON, XML from an IP source NOAA Weather, WeatherSnoop
Interacting with an IMAP mail server Email+
Interacting with an HTTP Web server Example HTTP Responder
Creating custom devices with states Simple: NOAA Weather, WeatherSnoop - Complex: EasyDAQ
Creating custom actions GhostXML
  • The per plugin preferences (pref) file is automatically managed (created, loaded, updated).
  • Or, if you're not sure the key exists:
  • The latter will return the second parameter if they key doesn't exist in the dictionary - it's your responsibility to add it to the prefs dict if you want it to be stored permanently.
  • A plugin can also insert other values into its pluginPrefs space (not just values shown in the plugin's config UI). This is a great way to maintain values that are not directly visible or available to the end user.
  • The Indigo server will save the plugin prefs automatically, but you can also cause them to be saved to the server immediately using:
indigo.server.savePluginPrefs
dev = indigo.devices["den fixture"]  # device ID preferred
newProps = dev.pluginProps
newProps["onCycles"] = 5
newProps["moreData1"] = "abc"
newProps["moreData2"] = True
Read plugin specific property ''onCycles'' from the Device "den fixture"
newProps["onCycles"] += 1
  • States defined in Devices.xml are automatically shown in the Trigger Event Device State Changed options when that plugin device type is selected, and are automatically shown in the Control Page editor when a control is created inspecting that plugin device.
dev = indigo.devices["Custom Plugin Thermostat"]  # device ID preferred
  • Plugins should subclass deviceStartComm and deviceStopComm to start/stop any hardware communication (normally via a new per-device thread):
  • Calls to deviceStartComm and deviceStopComm are automatically managed by the Indigo Server and Indigo Plugin Host. When a plugin first connects all enabled device instances owned by the plugin will receive deviceStartComm calls. Likewise, deviceStartComm is called when a new plugin device is created or duplicated. deviceStopComm is called whenever a plugin is disabled, deleted, or when the plugin is shutting down. Therefore, these two functions should be the primary bottlenecks for starting/stopping device hardware or network connections.
The XML in this file describes all events that your plugin will generate for use in Indigo. Your users will use these in the Trigger Events dialog just like any of the built-in Indigo events (like Power Failure, Email Received, etc.) Your plugin can offer other types of events, including update notifications, battery low notifications, button press notifications, and so on.
<?xml version="1.0"?>
<Events>
    <Event id="updateAvailable">
        <ConfigUI>
            <SupportURL>https://www.yourdomain.com/plugin/someOtherEvent.html</SupportURL>
            <Field id="someLabel" type="label">
                <Label>This label contains some useful configuration instructions.</Label>
            </Field>
          </ConfigUI>
    </Event>
</Events>
As you can see, your <Event> elements can define a <SupportURL> element as well – and separate support elements for the event's configuration dialog (the trigger events dialog now has a help button on it and if one of your events is selected clicking on the help button will take your user to the specified URL). You can specify an Event to be a separator in your event list so that when they're displayed in the UI there is a visual separation. Simply insert an Event defined like this between two other Event elements:
<Event id="sep1"/>
There are several Event-related and Trigger-related methods that you can add to your plugin.py file–some of which are required in order to have the Event do something. These methods include:
Element Description
self.closedEventConfigUi(self, values_dict, user_cancelled, type_id, event_id) Called after user clicks the Save button within the event configuration dialog (after 'validateEventConfigUi()' method has finished successfully). Used to finalize any Event configuration steps.
self.getEventConfigUiValues(self, plugin_props, type_id, event_id) Called when an Event configuration window is first opened.
self.getEventConfigUiXml(self, type_id, event_id) Called when an Event configuration window is first opened. The method is used to provide a valid XML payload in place of the Events.xml file.
validateEventConfigUi(self, values_dict, type_id, event_id) Called when a user clicks the Save button within the event configuration dialog. Used to provide configuration input validation to ensure the settings are within your parameters.
The power of Events
Indigo provides a method to do this by allowing the plugin to “subscribe” to changes for all objects in a particular class.
To monitor changes to different classes of Indigo objects, you can include a call to the appropriate subscribeToChanges method. Calling any of these methods tells Indigo to send a notification to the plugin of any changes to all objects of that type – not only plugin's own objects – so use these methods sparingly.
Element
indigo.schedules.subscribeToChanges()
indigo.controlPages.subscribeToChanges()
Element
self.deviceCreated(self, dev)
self.deviceDeleted(self, dev)
self.deviceUpdated(self, orig_dev, new_dev)
def deviceCreated(self, dev):
def deviceDeleted(self, dev):
    orig_dict = {}
    for (k, v) in orig_dev:
        orig_dict[k] = v
    new_dict = {}
    for (k, v) in new_dev:
        new_dict[k] = v
Monitor Changes to Variables
Element
self.variableCreated(self, var)
self.variableDeleted(self, var)
self.variableUpdated(self, orig_var, new_var)
  • /www/perceptive/wiki/data/pages/indigo_2025.2_documentation/plugin_extending_tutorial.txt
