Indigo Scripting Tutorial
Talking to the Indigo Server
The Indigo Plugin Host (IPH) provides a python scripting and plugin environment, which makes controlling the Indigo Server easy via the high-level python language (the official python website has great python tutorials). Every plugin automatically runs inside its own Indigo Plugin Host process, but you can also start the IPH in an interactive mode to directly communicate with the Indigo Server. It is a great way to experiment with Indigo's python environment, which is available to both python scripts run by Indigo and the plugin architecture. Want the ability to just put some Python scripts onto a menu somewhere for easy access? There's a simple way to do it.
Example Code Snippets
Device Examples
Turn off all devices:
indigo.device.allOff()
indigo.devices.len()
if hasattr(lamp, 'onState'):
isOn = lamp.onState
from datetime import datetime
Access a custom device state
# get the device dev = indigo.devices[23989834] # Some custom device # access the state through the states property, use the key # that's displayed in the Custom States tile on the main window # when you have a custom device selected print(dev.states["someDeviceStateKey"]) # show all the device states: print(dev.states)
Variable Examples
myVar = indigo.variables[123]
if myVar.value == "true":
Duplicating a variable:
import requests
my_unicode_string = "éçø"
my_integer = 1
my_float = 1.0
import json
my_new_dictionary["my_list"]
Custom Python classes that you create can implement the str(self) method. Take this simple example:
class myCustomClass:
def __init__(self):
self.a=1
self.b=2
def __str__(self):
return outputString
cl = myCustomClass() indigo.variable.updateValue(1234567, value=str(cl)) # the value of the variable in Indigo will look like this: 'a:1, b:2' not including the quotes
Date and Time Examples
Get the current server time:
indigo.server.getTime()
Action Group Examples
Execute an action group:
Execute Action Group 12345678 with extra event data:
Execute an action group, but pass through an arbitrary dictionary of data to actions that support using event_data:
extra_data = {"a": 1, "b": ["c", 2, 3]}
indigo.actionGroup.execute(12345678, event_data=extra_data)
Log Examples
import logging
Folder Examples
except ValueError as e:
myFolder = None
if lamp.folderId != 0:
lampsFolder = None
Event Data Examples
Webhook events pass data along the chain that can be easily accessed in embedded or linked scripts. The data is passed first to any conditional scripts. The event data can have many forms, but certain data will be passed regardless of the source of the call. By default, every event dictionary will contain the following:
A more robust event dictionary might look like this:
"data": (dict)
"event-indigo-id": 1234567890 (integer)
"event-plugin-event-id": simpleWebhook (string)
"event-plugin-id": com.indigodomo.webserver (string)
"event-plugin-name": Web Server (string)
"event-type": PluginEventTrigger (string)
"http-method": GET (string)
"request-url": https://localhost:8176/webhook/8143484549824dbba1286a873daa3cea (string)
"source": python (string)
"status-code": 200 (integer)
"timestamp": 2025-10-21T21:20:50 (string)
"webhook-id": 8143484549824dbba1286a873daa3cea (string)
Regardless of where the data came from (trigger, schedule, etc.) the variable name will be event_data. The data can be accessed like this:
# If you did an indigo.actionGroup.execute(12345) the source would be `python`.
# You don't need to import `event data`, it will be made available automatically.
if event_data["source"] == "python":
indigo.server.log(f"{event_data['timestamp']}") # or whatever
All event_data payloads will be formatted as <class 'indigo.Dict'>.
Miscellaneous Examples
Sending emails
# Simple Example
/usr/local/indigo/indigo-host
Connecting Remotely over SSH
What Else Can it Do?
indigo-host -e '
Executing Indigo Python Files
Executing AppleScript
indigo_attachments.py
import indigo
except ImportError:
raise ImportError
def log(message, label=None):
import indigo_attachments
raise ImportError
ImportError
Scripting Indigo Plugins
pluginServerApiVersion | str | The max API version supported by the running Indigo Server |
pluginSupportURL | str | The URL supplied by the plugin that points to its user documentation |
storeSummary | str | The description of the plugin in the plugin store (None if the plugin isn't in the plugin store) |
| Method | Description |
executeAction(actionId, deviceId, props, waitUntilDone) | This is the method that actually executes the action. actionId is the unique action id. deviceId is the id of the device that the action on which the action will perform (if it requires a device). props is a dictionary of properties that the action needs to process correctly. See the plugin's documentation for a description of what you need to pass in to execute actions. waitUntilDone is a boolean that tells the plugin to block until it can return an optional payload object. |
Plugin actions may return a value (a Python “primitive”) when you call the executeAction
method, but they are not required to. The return value can be any one of the following object types:
- None
None, - booleans
bool, - integers
int(), - floats
float(), - strings
str(), - Indigo Dicts
indigo.Dict(), - Indigo Lists
indigo.List().
Restart a Plugin
airfoil_plugin.restart()
Wait Until Done
if airfoilPlugin.isEnabled():
'getSources',
deviceId=12345678 # ID of Airfoil device,
waitUntilDone=True
except Exception as e:
audioDevices : (list)
Item : (dict)
icon : [SNIP]
Item : (dict)
icon : [SNIP]
Item : (dict)
icon : [SNIP]
recentApplications : (list)
Item : (dict)
icon : [SNIP]
Item : (dict)
icon : [SNIP]
systemAudio : (list)
Item : (dict)
icon : [SNIP]
