NOAA Weather
Plugin Config
- Degrees F
- Degrees C
- Degrees F (Degrees C)
- Degrees C (Degrees F)
Creating Weather Forecast, Current Conditions, and Weather Alerts Devices
There are three additional weather device types that can provide additional weather data – Alerts, Conditions, and Forecast data. These devices are based on more precise location information – your lat/long coordinates (or any valid coordinates you provide) – rather than being linked to a weather station (which may not be nearby). The creation and configuration of these devices is very straightforward.
Weather Station and Current Conditions Device States
Current Condition- The current condition in a word or twoCurrent Condition Icon- The current condition icon - Indigo ships with “NOAA Condition+.png” and it's children, one for each condition that's returned in this field. So, in the control page editor, select this state and “NOAA Condition+.png” and you'll have a nice conditions icon (images provided by NOAA).Dew Point °C- Dew point in CelsiusDew Point °F- Dew point in FahrenheitDew Point String- Dew point in a human-readable stringHeat Index °C- Heat index in CelsiusHeat Index °F- Heat index in FahrenheitHeat Index String- Heat index in a human-readable stringHumidity- The relative humidityLatitude- LatitudeLocation- Location in human-readable formLongitude- LongitudeObservation Date/Time- The last time NOAA updated the data. This field is inYYYY-MM-DD HH:MM:SSso it can be parsed by other software if needed.Pressure (inches)- Pressure in inchesPressure (mbar)- Pressure in millibarsQuality Codes- For scripters to account for the relative quality of the various weather observations (JSON). See below for what the codes mean.Temperature °C- Temperature in CelsiusTemperature °F- Temperature in FahrenheitTemperature String- Temperature in a human-readable string (i.e. “98.0 F (36.7 C)”) - this is the state shown in the “State” column for a Weather Station deviceTime Zone- The timezone as it applies to the observed location.Visibility- Visibility in milesWind Degrees- Wind direction in degreesWind Direction- Wind direction description in something close to human-readable formWind Knots- Wind speed in knotsWind MPH- Wind speed in miles per hourWind String- A description of the wind in human-readable form
Weather Alert Device States
Weather Forecast Device States
Quality Codes
The NOAA Weather plugin includes a qualityCodes state. This state includes information (from NOAA) on the perceived quality of select data elements. An example qualityCodes state value is:
| MADIS QC Information - Surface QC Data Descriptor Values | |
| No QC available | |
| Z | Preliminary, no QC |
| Automated QC checks | |
| C | Coarse pass, passed level 1 |
| S | Screened, passed levels 1 and 2 |
| V | Verified, passed levels 1, 2, and 3 (BEST) |
| X | Rejected/erroneous, failed level 1 |
| Q | Questioned, passed level 1, failed 2 or 3, where: |
| Quality Levels | |
| level 1 = validity | |
| level 2 = internal consistency, temporal consistency, statistical spatial consistency checks | |
| level 3 = spatial consistency check | |
import json
dev = indigo.devices[12345678] codes = dev.states['qualityCodes'] quality_codes = json.loads(codes) temp_quality = quality_codes['temperature']
indigo.server.log("trust")
Weather Icons
Weather Station and Current Condition Devices
You can link to the current condition icons in the “traditional” way. On a control page, select Display Device State and Current Condition Icon. Then select As Image and choose NOAA Condition+.png. This should work for both the Weather Station and Current Condition device types.
Forecast Devices
For Forecast icons, the reference is a bit different. NOAA provides a detailed description of the icon like, /icons/land/day/tsra,30?size=medium. The way to display these images is to link to them directly via the NOAA API itself. Select Display Refreshing Image URL, set the icon size you want (medium is 86×86) and then in the URL field, enter a URL which is a combination of text and a device state substitution. The text part is https://api.weather.gov and then append the substitution string for the state you want like %%d:123456789:icon_01%%. So the full URL would be:
https://api.weather.gov%%d:123456789:icon_01%%
(replacing 123456789 with your device ID and then the icon you want like icon_01, icon_02, etc.)
You can also construct refreshing image URLs for the current conditions icons, but the construction is a little different. The full URL for those would be something like, https://api.weather.gov/icons/land/day/%%d:123456789:currentConditionIcon%%.
If you want to have both day and night versions, you'd need to create a variable value that is equal to day when Indigo's isDaylight variable is true and equal to night when isDaylight is false. Then add a variable substitution for that part of the URL, like:
https://api.weather.gov/icons/land/%%v:12345678%%/%%d:123456789:currentConditionIcon%%.
For all these URLs, there's no need to refresh the images more than once every half hour or so because the NOAA plugin weather devices don't update more frequently than that on their own.
Scripting Support
Support and Troubleshooting
