NOAA Weather
  • Degrees F
  • Degrees C
  • Degrees F (Degrees C)
  • Degrees C (Degrees F)
There are three additional weather device types that can provide additional weather data – Alerts, Conditions, and Forecast data. These devices are based on more precise location information – your lat/long coordinates (or any valid coordinates you provide) – rather than being linked to a weather station (which may not be nearby). The creation and configuration of these devices is very straightforward.
NOAA Trigger States Image
  • Latitude - Latitude
  • Longitude - Longitude
  • Observation Date/Time - The last time NOAA updated the data. This field is in YYYY-MM-DD HH:MM:SS so it can be parsed by other software if needed.
  • Quality Codes - For scripters to account for the relative quality of the various weather observations (JSON). See below for what the codes mean.
  • Time Zone - The timezone as it applies to the observed location.
The NOAA Weather plugin includes a qualityCodes state. This state includes information (from NOAA) on the perceived quality of select data elements. An example qualityCodes state value is:
MADIS QC Information - Surface QC Data Descriptor Values
No QC available
Z Preliminary, no QC
Automated QC checks
C Coarse pass, passed level 1
S Screened, passed levels 1 and 2
V Verified, passed levels 1, 2, and 3 (BEST)
X Rejected/erroneous, failed level 1
Q Questioned, passed level 1, failed 2 or 3, where:
Quality Levels
level 1 = validity
level 2 = internal consistency, temporal consistency, statistical spatial consistency checks
level 3 = spatial consistency check
  import json
      indigo.server.log("trust")
Weather Station and Current Condition Devices
You can link to the current condition icons in the “traditional” way. On a control page, select Display Device State and Current Condition Icon. Then select As Image and choose NOAA Condition+.png. This should work for both the Weather Station and Current Condition device types.
Forecast Devices
For Forecast icons, the reference is a bit different. NOAA provides a detailed description of the icon like, /icons/land/day/tsra,30?size=medium. The way to display these images is to link to them directly via the NOAA API itself. Select Display Refreshing Image URL, set the icon size you want (medium is 86×86) and then in the URL field, enter a URL which is a combination of text and a device state substitution. The text part is https://api.weather.gov and then append the substitution string for the state you want like %%d:123456789:icon_01%%. So the full URL would be:
https://api.weather.gov%%d:123456789:icon_01%%
(replacing 123456789 with your device ID and then the icon you want like icon_01, icon_02, etc.)
You can also construct refreshing image URLs for the current conditions icons, but the construction is a little different. The full URL for those would be something like, https://api.weather.gov/icons/land/day/%%d:123456789:currentConditionIcon%%.
If you want to have both day and night versions, you'd need to create a variable value that is equal to day when Indigo's isDaylight variable is true and equal to night when isDaylight is false. Then add a variable substitution for that part of the URL, like:
https://api.weather.gov/icons/land/%%v:12345678%%/%%d:123456789:currentConditionIcon%%.
For all these URLs, there's no need to refresh the images more than once every half hour or so because the NOAA plugin weather devices don't update more frequently than that on their own.
  • /www/perceptive/wiki/data/pages/indigo_2025.2_documentation/plugins/noaaweather.txt
