Scenes (Indigo 6)
With the addition of Z-Wave (and various plugins that define dimmer and relay devices) it's become obvious that we needed to provide some way to create technology-agnostic scenes. You can, of course, implement basic scenes through Action Groups, and for many cases that's good enough.
To create a scene, you just create a new device, select Scenes from the Type menu, select On/Off Scene from the model menu, and you'll see the configuration dialog:
Scenes Configuration Image
  • All devices are ON - so the scene state will be set to ON when all devices in the scene are ON
  • Any device is ON - so the scene state will be set to ON when any of the devices in the scene are ON
To use a scene device, just use the standard Control Light/Appliance action to turn it ON/OFF, and create triggers on the scene's ON and OFF state. That's it!
  • /www/perceptive/wiki/data/pages/indigo_2025.2_documentation/plugins/scenes.txt
