SQL Logger Plugin
- Download a PostgreSQL installer. Note there are other installers available elsewhere as well.
- Add the path to the PostgreSQL binary to your bash profile file. From the Terminal copy/paste:
- Next, open the System Preferences and choose the PostgreSQL Server icon that was added. You should now be able to start the server. Note that some installers seem to include a Server Manage.app application, but they may not work correctly. However, the panel in the System Preferences does appear to work.
- From the command line you can now try to connect to the server via:
psql -U postgres
- Next, select the
Plugins→SQL Logger→Configure…menu item, then selectPostgreSQLas the database type.
Logging Options
Database Table Format
and
Using SQL you can query the table for all the defined columns.
| ts | value |
Example Queries
PostgreSQL Queries
SQLite Queries
Note that when selecting the timestamp from a SQLite table you must use the notation datetime(ts,'localtime') so that the internally stored GMT time is translated to your local time.
Events
Aug 9, 2012 3:38:10 AM My Type Error this is an error from a script NOAA Weather Plus Error Error parsing XML from NOAA for device Weather Forecast: not well-formed (invalid token): line 1, column 111
You can enter text in the String to Match field and the action will attempt to match it against the text in the log message. For instance, entering Office Lamp in the field will cause the event to fire only if “Office Lamp” is in the field (case-sensitive). You can also specify a regular expression for more advanced text matching.
Scripting Support
Support and Troubleshooting
