Python Packages and Indigo
This page describes how Indigo 2025.2.0 works with Python, specifically with respect to packages/libraries.
Indigo 2025.2 shipped with API version 3.4 and is the first version to contain support for Python version 3 (check the API Version Chart to see what version of the API is available in which Indigo versions). With this version of the API, Python 3 is now automatically installed as part of the Indigo installer. For Indigo 2025.2, we are including Python 3.11.6.
The Indigo 2025.2 installer includes the Python installer (including Intel and Apple Silicon support) from https://www.python.org - the official Mac installers for the Python language. As a result, any installs of other versions of Python from that website may cause unexpected results in Indigo and potentially cause it to break. We've taken all precautions we can try to avoid conflicts, but there is only so much we can do. So please use caution when installing other Python versions to your server machine. If you have any questions about other Python versions, post your questions on our forums.
Installing Additional Python Packages with Indigo 2025.2
As noted above, Indigo 2025.2 ships with Python 3.11 and which contains several modules in addition to Python's standard core modules. The specific modules installed with each version of Python are listed below. However, in some instances, you may need to manually install one or more additional Python packages to support a third-party plugin or your own custom scripts. The manner in which this is done, depends on the Indigo API version that the plugin supports.
user@my mac ~ % pip3 list
Package            Version
astroid            2.9.3
certifi            2021.10.8
charset-normalizer 2.0.11
cycler             0.11.0
fonttools          4.29.1
user@my mac ~ %
Version: 2.27.1
Author: Kenneth Reitz
Author-email: [email protected]
License: Apache 2.0
Required-by:
user@my mac ~ %
Installing additional Python versions on the Indigo 2025.2 server machine is NOT recommended (see above). Installing additional Python modules should only be done when necessary.
The PYTHONPATH for IPH3 is:
zeroconf==0.130.0
websocket-client==1.7.0
Best Practices:
If you're using GitHub, be sure that the contents of the ../Packages folder is included in your .gitignore file. This will ensure the Contents/Packages/pip-install-log-success.txt and any other content is not included as a part of your package. When testing your plugin, you should include any needed binaries in this folder so when you publish an update, the binaries will not be included.
Troubleshooting:
If you're working on transitioning from included binaries to using a requirements.txt file, be sure to remove the deprecated binaries from your package. If they're present, Indigo may favor those over the libraries you're trying to install automatically.
Manual Installation by User
Using pip:
Logging Import Errors
import_errors = []
    import zeroconf
except ImportError:
def startup(self):
    if len(import_errors):
        for i in import_errors:
        self.logger.error(msg)
        return "Plugin startup canceled due to missing Python libraries."
Access to IPH3 Libraries
Method Access to
IPH3 Libraries
plugins yes
embedded scripts yes
linked scripts yes
Python Packages for Scripters
  1. IndigoPluginHost3
  • /Library/Application Support/Perceptive Automation/Scripts – any linked scripts you use for Indigo Schedules and Actions using the “Execute Script > Script and File Actions” command should be stored in this folder.
  • /Library/Application Support/Perceptive Automation/Python3-includes – any modules you have developed (a module is a file that contains classes, functions, constants, etc.) that you want to share across multiple scripts, should be stored in the /Library/Application Support/Perceptive Automation/Python3-includes folder. (Indigo versions prior to 2022 should use the /Library/Application Support/Perceptive Automation/Python2-includes folder).
If Something Goes Wrong
Indigo 2025.2 ships with support for the following Python 3 packages in addition to the packages installed with the standard Python framework. Generally, if earlier versions of the listed packages are installed at the location Indigo uses, they will be upgraded to the version numbers below. The >= symbol means the version installed by Indigo may be newer than the version listed, but will not be older. pyserial is also installed but is installed differently than the other packages listed above and should be unmodifiable. Libraries marked with * are dependencies and may get newer versions on later installs. You should not update any of the libraries listed as they (and their dependencies may rely on a specific version.)
PIP installed by Indigo
PIP Modifiable (but not recommended)
Package Version
* aiofiles >=24.1.0
* anyio >=4.8.0
certifi ==2023.11.17
* cffi >=1.17.1
charset_normalizer ==3.3.2
* contourpy >=1.3.1
cryptography ==41.0.7
* cycler >=0.12.1
dictdiffer ==0.9.0
* fonttools >=4.56.0
future ==0.18.3
* h11 >=0.14.0
* html5tagger >=1.3.0
* httpcore >=1.0.7
* httptools >=0.6.4
httpx ==0.25.2
idna ==3.6
janus ==1.0.0
* jedi >=0.19.2
Jinja2 ==3.1.2
* kiwisolver >=1.4.8
MarkupSafe ==2.1.3
matplotlib ==3.8.2
* multidict >=6.1.0
* numpy >=1.26.4
oauthlib ==3.2.2
* packaging >=24.2
* parso >=0.8.4
Pillow ==11.1.0
pudb ==2023.1
py-applescript ==1.0.3
pyaes ==1.6.1
* pycparser >=2.22
* Pygments >=2.19.1
pyobjc ==10.0
pyparsing ==3.1.1
python-box ==7.3.2
python-dateutil ==2.8.2
requests ==2.31.0
requests-oauthlib ==1.3.1
sanic ==23.6.0
* sanic-routing >=23.12.0
sanic-session ==0.8.0
scipy ==1.11.4
six ==1.16.0
* sniffio >=1.3.1
* tracerite >=1.1.1
* typing_extensions >=4.12.2
* ujson >=5.10.0
urllib3 ==2.1.0
* urwid >=2.6.16
* urwid-readline >=0.15.1
* uvloop >=0.21.0
* wcwidth >= 0.2.13
websockets ==14.1
xmljson ==0.2.1
pyserial 3.5
This section contains notes and examples about some library features that may be of particular help to developers.
Depending on your Indigo version, we may have installed the Python-Box library. This library allows the user to use JavaScript style dot notation to access parts of a collection. There are good descriptions of all the functionality on the library's page link above. What we were most interested in is a `box` instance that has the `box_dots` option set to true, like this:
my_box = box.Box(some_dict, box_dots=True)
This allows developers to specify a string using JavaScript style dot notation to get to parts of the `box` object:
some_element = my_box["keyhere.[0].anotherkey"]
Here are some concrete examples:
import box
# Given this dictionary
my_dict = {
my_box = box.Box(my_dict, box_dots=True)  # create a box object of my_dict
dict_in_list = my_box["a-list.[2].dict-in-list"]  # equals "fun stuff"
int_from_list = my_box["a-list.[0]"]  # equals 1
a_dict = my_box["a-dict"]  # equals {'first': 'first element', 'second': 'second element'}
This is useful in a variety of ways, but we use it extensively in the Event Data Passing and Webhook features. You can determine whether you have the box library installed by simply trying to import it into a scripting shell or embedded script.
  • /www/perceptive/wiki/data/pages/indigo_2025.2_documentation/python_packages.txt
