Python Version Conflicts
  1. /Library/Frameworks/Python.framework/Versions/3.11/bin/python3 - this is the most explicit way to start up the 3.11 interpreter installed by Indigo.
  2. /usr/local/bin/python3.11 - this is a symlink to the above option, and has the same downside. In addition, though, since it's a symlink in a more public directory, it could get updated by something else entirely.
  3. /Library/Frameworks/Python.framework/Versions/Current/bin/python3 - the downside to this option is that if you (for some reason) install an older version, the installer might update that link to point to the older version.
  4. /usr/local/bin/python3 - this option is created/maintained by the Python installer as well, so it has the same benefits/issues of the last option, but also since it's a symlink it could get munged by some other installer (homebrew/macports).
  1. /Library/Frameworks/Python.framework/Versions/3.11/bin/pip3 - this is the most explicit way to start up the 3.11 interpreter installed by Indigo.
  2. /usr/local/bin/pip3.11 - this is a symlink to the above option, and has the same downside. In addition, though, since it's a symlink in a more public directory, it could get updated by something else entirely.
  3. /Library/Frameworks/Python.framework/Versions/Current/bin/pip3 - the downside to this is that if you (for some reason) install an older version, the installer might update that link to point to the older version.
  4. /usr/local/bin/pip3 - this option is created/maintained by the Python installer as well, so it has the same benefits/issues of the last option, but also since it's a symlink it could get munged by some other installer (homebrew/macports).
Xcode
homebrew & macports
They will insert paths into the various .login, .profile, .bashrc files such that their version of Python (and its executables) are found first when typing any of the Python commands from the shell without a full path. They set the PYTHONPATH (which is a list of file system paths that the Python interpreter looks in to find modules not part of the standard install like those installed by pip3) so that they look in their own site-packages directories
  • /www/perceptive/wiki/data/pages/indigo_2025.2_documentation/python_version_conflicts.txt
