Server Commands (indigo.server.*)
Commands that aren't associated with any specific object type are collected up in the indigo.server.* command namespace.
| Parameters |
| direct parameter | No | datetime.date | a datetime.date object representing the day to calculate the sunrise time for |
| Parameters |
| Parameters |
Get Latitude and Longitude
lat = latLong[0]
long = latLong[1]
| Parameters |
| Parameters |
for posixPath in ports:
print(posixPath)
print(uiName)
# iterate through both
print(posixPath)
print(uiName)
indigo.server.getTime()
No Parameters
| Parameters |
| direct parameter | Yes | string | this is the text that’s written to the log |
isError | No | boolean | if True, it will show up in red in the event log - default is False - if no type is included, the name of the plugin will automatically be used with “ Error” appended |
| Parameters |
| Parameters |
