Server Commands (indigo.server.*)
Commands that aren't associated with any specific object type are collected up in the indigo.server.* command namespace.
lat = latLong[0]
long = latLong[1]
for posixPath in ports:
	print(posixPath)
	print(uiName)
# iterate through both
	print(posixPath)
	print(uiName)
indigo.server.getTime()
No Parameters
indigo.server.sendEmailTo("[email protected]")
  • /www/perceptive/wiki/data/pages/indigo_5_documentation/server_commands.txt
