Link to this comparison view
indigo_5_documentation:advanced_powerlinc_options [2019/01/25 22:53]
indigo_5_documentation:advanced_powerlinc_options [2019/01/26 00:10] (current)
Line 1: Line 1:
 +====== Advanced PowerLinc Options ======
 +Indigo provides some advanced options for the various PowerLinc INSTEON interfaces. Select **''​Configure...''​** from the **''​Interfaces->​INSTEON/​X10 Power Line''​** menu, then (assuming you have a PowerLinc interface selected) click on the **''​Interface Options...''​** button. You'll see the **''​Advanced PowerLinc Options''​** dialog:
 +{{:​indigo_5_documentation:​advanced_powerlinc_options.png|}}
 +The first two options should always be checked by default - you really only want to disable those options if the Indigo Support team recommends it.
 +From this dialog, you can also perform some other link syncing operations: ​
 +  * Start/Stop Link Sync (same as using the menu items on the **''​Interfaces->​INSTEON/​X10 Power Line''​** menu)
 +  * On your PowerLinc, you can clear all of it's internal links, read all the links, and sync links. You normally won't use these options unless instructed by Indigo Support
 +  * You can completely reset your PowerLinc and resync the links all in one go - this is roughly synonymous to doing a factory reset, but not quite. Indigo support will often recommend doing a factory reset vs using this option because the factory reset performs some actions that we can't do through software.
indigo_5_documentation/advanced_powerlinc_options.txt ยท Last modified: 2019/01/26 00:10 (external edit)
© Perceptive Automation, LLC. · Privacy
