indigo_5_documentation:advanced_powerlinc_options [2019/01/25 22:53] |
indigo_5_documentation:advanced_powerlinc_options [2019/01/26 00:10] (current) |
Line 1: | Line 1: | ||
+ | ====== Advanced PowerLinc Options ====== | ||
+ | Indigo provides some advanced options for the various PowerLinc INSTEON interfaces. Select **''Configure...''** from the **''Interfaces->INSTEON/X10 Power Line''** menu, then (assuming you have a PowerLinc interface selected) click on the **''Interface Options...''** button. You'll see the **''Advanced PowerLinc Options''** dialog: | ||
+ | {{:indigo_5_documentation:advanced_powerlinc_options.png|}} | ||
+ | The first two options should always be checked by default - you really only want to disable those options if the Indigo Support team recommends it. | ||
+ | From this dialog, you can also perform some other link syncing operations: | ||
+ | * Start/Stop Link Sync (same as using the menu items on the **''Interfaces->INSTEON/X10 Power Line''** menu) | ||
+ | * On your PowerLinc, you can clear all of it's internal links, read all the links, and sync links. You normally won't use these options unless instructed by Indigo Support | ||
+ | * You can completely reset your PowerLinc and resync the links all in one go - this is roughly synonymous to doing a factory reset, but not quite. Indigo support will often recommend doing a factory reset vs using this option because the factory reset performs some actions that we can't do through software. |
