In the IOM, all devices are derived from a common Device
base class. This base class provides for all the common properties of a device (including devices defined by Server plugins) and each subclass also inherits all the commands in the device command namespace (indigo.device.*
) - there are a few exceptions that will be noted below. Check out the examples for each section to see how you use each device type.
To create, duplicate, delete, and send commands to a device, use the appropriate command namespace as defined below
To modify an device's definition get a copy of the device, make the necessary changes, then call myDevice.replaceOnServer()
To update a plugin's props on a device on the server, call myDevice.replacePluginPropsOnServer(newPropsDict)
rather than try to update them on the local device
To change a device's state on the server, use myDevice.updateStateOnServer(key=“keyName”, value=“Value”)
Device Base Class
The Device
class is generally used as a base class - your script will use objects that are instances of one of it’s subclasses - we'll discuss each of the subclasses later in this section. First, a quick refresher on a fundamental aspect of devices: some devices can only be controlled (i.e. old-style ApplianceLincs, most X10 devices, etc.), called responders in Indigo terminology, other devices are only controllers (i.e. RemoteLincs, PalmPads, etc.), and some devices are both responders and controllers (i.e. KeypadLincs).
Device Base Class Properties
address | string | No | the address for the device |
buttonGroupCount | integer | No | the number of groups (or buttons in the case of the RemoteLinc and ControLinc) that the controller supports - currently used only for INSTEON devices - 0 for other devices |
description | string | Yes | a description of the device as specified by the user |
deviceTypeId | string | No | the typeId specified in the Devices.xml (or it’s documentation) - only used for plugin defined devices |
enabled | boolean | No | is the device enabled - set using the indigo.device.enable() method |
folderId | integer | No | the unique ID of the folder this device is in (0 if it's not in a folder) - use moveToFolder() method to change |
globalProps | dictionary | No | an indigo.Dict() representing all name/value pairs associated with this device - each plugin will have it's own dictionary (globalProps[pluginId] ) - see About Plugin Properties below for details |
id | integer | No | id or instance of the device, assigned on creation by IndigoServer |
lastChanged | datetime | No | the last date/time that the device was changed - populated by IndigoServer |
model | string | No | the model name of the device - defined either by Indigo based on type or by the plugin's device definition |
name | string | Yes | the unique name of the device - no two devices can have the same name |
pluginId | string | No | if protocol is Plugin , the string ID for the plugin |
pluginProps | dictionary | No | an indigo.Dict() representing the name/value pairs defined by your plugin for the device - plugin developers should publish this information if you want other plugins/scripts to create devices of this type - see About Plugin Properties below for details - use replacePluginPropsOnServer() method to change |
protocol | kProtocol | No | an enumeration specifying the protocol of the device - see protocol enumeration below for possible values |
remoteDisplay | boolean | Yes | should this device be displayed in remote clients (IWS, Indigo Touch, etc) - may also be set with indigo.device.displayInRemoteUI() |
states | dictionary | No | returns an indigo.Dict() of device states - the key is the state id and the value is the value. Note that enumerated states will have not only the state, but also each option for the state. So, for instance, if I had a state called status and it had 3 options (online, offline, error), then you'd not only have status as a key, but also status.online, status.offline, and status.error as keys in the dictionary. This is so that you can test each state enumeration independently in trigger actions (e.g. status.online is true). |
supportsAllLightsOnOff | boolean | No | indicates that this device should react to all lights On and all lights Off commands - always False for plugin defined devices |
supportsAllOff | boolean | No | indicates that this device should react to all Off commands - always False for plugin defined devices |
supportsStatusRequest | boolean | No | indicates if the device supports querying the status - always False for plugin defined devices |
Protocol Enumeration
indigo.kProtocol |
Value | Description |
Devices have properties - some are class properties, defined by the class itself. One of the biggest requests we've gotten in the past is some way to add arbitrary properties to a device - so that you could store your own data with the device in the database. And with plugin defined devices, we needed a place to store the properties that you need to operate the device. That's what the pluginProps
and globalProps
is a dictionary of every additional property defined for the device - each plugin has it's own dictionary of props in here which are readable by anyone. pluginProps
is a shortcut to get to your plugin's props and are only writable by your plugin once the plugin has been created - a script can create a device supplied by your plugin along with the necessary properties, which are passed in on the create()
method. You should publish the properties necessary to make your device work so that scripters can create your devices.
dev=indigo.devices[123]
dev.replacePluginPropsOnServer({"pollInterval":10,"checkForUpdates":True})
defined for the device, those properties are also stored here - so in order to make sure your device works correctly you must include those properties as well. If you need to update several properties in your props dict, you can use the update()
method:
localPropsCopy.update({"pollInterval":10,"checkForUpdates":True})
The update()
method will change the properties specified, and add the property if it doesn't exist. Now, you might be wondering - why do the extra localPropsCopy = dev.pluginProps
dev.pluginProps.update({"pollInterval":10,"checkForUpdates":True})
Because the dev object is read-only - when you reference dev.pluginProps
, it returns a copy rather than returning a reference to the read-only object. So, in effect, you'd be modifying a copy. But, because you aren't saving a reference to that copy, it goes away since the next time you reference dev.pluginProps
another copy is made.
About Custom Device States
<State id="playStatus">
<State id="sep1">
<State id="playlist">
<ValueType>String</ValueType>
<State id="album">
<State id="artist">
<State id="track">
<State id="volume">
<State id="shuffle">
It's actually pretty simple. When your plugin detects a change in one of the states, you just call the updateStateOnServer(“id”,value=“value”)
method. Here are some examples for setting the state based on the above state definitions:
# to update the volume state
someMusicServer.updateStateOnServer("volume", value=50)
# to update the track name
someMusicServer.updateStateOnServer("track", value="Cluster One")
# to update the album name
someMusicServer.updateStateOnServer("album", value="The Division Bell")
# to update the artist name
someMusicServer.updateStateOnServer("artist", value="Pink Floyd")
# to update the playStatus
someMusicServer.updateStateOnServer("playStatus", value="playing")
someMusicServer.updateStateOnServer("shuffle", value=True)
Note - for states that have a <ValueType>
of Number
, you pass an integer or float; for states that are Boolean
, you pass Python True
or False
; all others pass a string.
It's just that simple. This will cause any triggers on the server that are set on your device's states to be fired. It will update any visible control pages. It will show the state that's defined in the <UiDisplayStateId>
element in the Mac device table's State
column.
The updateStateOnServer
method has 2 optional parameters: decimalPlaces
(integer) and triggerEvents
(boolean). When updating floating point state values use the decimalPlaces
parameter to specify the number of fractional digits to store and display. For example:
someThermmostateDevice.updateStateOnServer("mainTemp" value=76.1234, decimalPlaces=2)
The triggerEvents
parameter can be set to False (defaults to True) to have the Indigo Server update the state but ignore any Device State Changed triggers that should be processed as a result of the state change.
Commands (indigo.device.*)
All Off
Command Syntax Examples |
indigo.device.allOff()
Parameters |
direct parameter | Yes | kAllDeviceSel | enumerated value to indicate which devices to turn off, all if no parameter is passed - see the kAllDeviceSel enumeration for a full description |
indigo.kAllDeviceSel |
Enumerated Type | Description |
Create a device. You can create devices that are defined by your plugin, in other plugins, and X10 devices (
you can't currently add INSTEON devices because they need to perform some action to actually make the device function). You use this method to create ALL device types - it will return a device of the correct class to you based on the arguments. It can be considered the “device” factory method.
address="F8",
name="Device Name Here",
pluginId="com.mycompany.pluginId",
deviceTypeId="myDeviceTypeId",
props={"propA":"value","propB":"value"},
folder=1234)
Parameters |
protocol | Yes | kProtocol | the protocol for the device (indigo.kProtocol.Plugin or indigo.kProtocol.X10 ) |
indigo.device.delete(123)
Parameters |
direct parameter | Yes | integer | id or instance of the device to delete |
indigo.device.duplicate(123, duplicateName="New Name")
Parameters |
direct parameter | Yes | integer | id or instance of the device to duplicate |
Enable/Disable
Parameters |
direct parameter | Yes | integer | id or instance of the device to enable/disable |
Parameters |
direct parameter | Yes | integer | id or instance of the device |
Parameters |
direct parameter | No | integer | id or instance of the device |
Parameters |
Status Request
Parameters |
direct parameter | Yes | integer | the id of the device |
suppressLogging | No | boolean | True to keep the request from being logged into the event log window (default is False ) |
Toggle
indigo.device.toggle(123)
Parameters |
Turn Off
indigo.device.turnOff(123)
Parameters |
Turn On
indigo.device.turnOn(123)
Parameters |
Here’s a side by site comparison of using various device properties in Python and AppleScript:
Python | AppleScript |
# Creating a device
name="Office Lamp",
address="F7",
| -- Creating a device
address:"F7",¬
# Getting a device
| -- Getting a device
| -- Logging a message if it’s an X10 device
log "device is an X10 device"
end if
if (myDevice.remoteDisplay):
| -- Logging a message if it’s showing in Indigo Touch
end if
| -- Folder ID is not available in AppleScript
| -- Turning off all devices (dimmer and relay)
all off
all lights off "A"
-- AppleScript
DimmerDevice
ledStates | list | No | this is a list of booleans that represent the state of LEDs on the device. So, to check to see if LED 3 is on you'd check dev.ledStates[2] (Python arrays are 0-based so the first element is element 0). Currently, only KPL devices use this array - however, future devices may use it as well so you should probably check the length first to make sure that the LED you're looking for is actually there. Use the len(dev.ledStates) method to see how many entries there are before you access a specific index. |
onState | boolean | No | indicates whether the device is on - set using commands below |
Commands (indigo.dimmer.*)
All Lights Off
indigo.dimmer.allLightsOff()
Parameters |
direct parameter | No | kAllDeviceSel | enumerated value to indicate which devices to turn off, all if no parameter is passed - see the kAllDeviceSel enumeration for a full description |
All Lights On
indigo.dimmer.allLightsOn()
Parameters |
direct parameter | No | kAllDeviceSel | enumerated value to indicate which lights to turn on, all if no parameter is passed - see the kAllDeviceSel enumeration for a full description |
Brighten
indigo.dimmer.brighten("Office Lamp")
indigo.dimmer.brighten(123)
indigo.dimmer.brighten("Office Lamp", by=50, delay=4)
Parameters |
Dim
indigo.dimmer.dim("Office Lamp")
indigo.dimmer.dim(123)
indigo.dimmer.dim("Office Lamp", by=50, delay=4)
Parameters |
Set Brightness
Parameters |
Set LED State
Parameters |
Set On State
Here’s a side by site comparison of dimmer properties in Python and AppleScript:
# Getting a device
| -- Getting a device
(myDevice.onState)):
| -- Set a device’s brightness to 75 if it’s currently
end if
| -- Brighten a light by 25% after 10 minutes
end if
myDevice.folderId
# OR
That code works correctly, but is very inefficient. The Python to C++ bridge will cause a copy of the object to be made every time indigo.devices[123]
is used since the devices list is a C++ object, but the object returned from it using the id subscript is bridged to a Python object, and all bridged objects are copies. So, the code directly above will create 3 copies of the device object - very inefficient. The code in the example above gets a single copy of the object and uses that in all the rest of the code. A good rule of thumb is to get an explicit copy of an object if you need to use it more than once.
analogInputs | list of integer | No | a list of the current analog input values, one per input |
binaryInputs | list of boolean | No | a list of the current binary input values, one per input |
binaryOutputs | list of boolean | No | a list of the current binary output values, on per output (max 12 total outputs) |
sensorInputs | list of integer | No | a list of the current sensor input values, one per input |
Commands (indigo.iodevice.*)
Set Binary Output
Parameters |
index=1,
value=False)
| -- If binary input 3 is false, set binary output 1
-- to false
of device "EZIO8SA"
of device "EZIO8SA"
"EZIO8SA" to theBinaryOutputs
end if
SensorDevice
Some sensor devices, like motion sensors, are treated differently in Indigo. They aren't generally directly controllable and are considered input devices.
They typically send a command of some type when they detect some condition and send another command when they stop detecting it. However, dealing with them in Indigo as if they maintain state is much more useful in many cases. So, Indigo will attempt to maintain a virtual state for each motion sensor if configured that way. Currently, the following devices fall under this category:
X10 Motion Sensors
the Wireless INSTEON Motion / Occupancy Sensor (2420M) from SmartLabs
the TriggerLinc from SmartLabs
the SynchroLinc from SmartLabs
Other sensor types, such as an energy meter (iMeter solo), do maintain some state information (like current load in Watts). Indigo maintains additional virtual states for these types of devices as well though, for example to track the kWh of energy used from a base time stamp.
onState | boolean | No | indicates that the device is currently detecting motion |
energyInputCount | integer | No | number of energy (current) monitoring inputs this device supports |
energyInputs | list of integer | No | a list of the energy input values in Watts, one per input |
accumEnergyTotals | list of float | No | a list of the energy used in kWh since the last base time specified in accumEnergyBaseTimes , one per input |
accumEnergyTimeDeltas | list of integer | No | a list of the time delta in seconds since the last base time, one per input |
accumEnergyBaseTimes | list of datetime | No | a list of the base times from which to calculate energy totals (accumEnergyTotals ), one per input |
Commands (indigo.sensor.*)
Set On State
Parameters |
value | Yes | boolean | True to set Indigo’s state to on, False to set it to off |
Reset Accumulated Energy Totals
Resets the accumEnergyTotals
, accumEnergyTimeDeltas
values for all inputs properties and changes the accumEnergyBaseTimes
to the server's current datetime.
indigo.sensor.resetAccumEnergyTotals(123)
Parameters |
Because this can't be done in AppleScript, we've just provided an example in Python:
# Log to the Event Log the current kWh total for an energy meter (ID 123):
dev = indigo.devices[123]
indigo.server.log("current kWh total: " + str(dev.accumEnergyTotals[0]))
# Then reset the accumulative totals and log again (should be 0):
indigo.sensor.resetAccumEnergyTotals(dev)
dev.refreshFromServer(waitUntilServerIdle=True)
indigo.server.log("reset kWh total: " + str(dev.accumEnergyTotals[0]))
RelayDevice
Property | Type | Description | |
onState | boolean | indicates whether the device is on | |
Commands (indigo.relay.*)
Set LED State
Parameters |
# Toggle the device
| -- Toggle the device
toggle device “Office Lamp”
SprinklerDevice
activeZone | integer | No | the number of the active zone, -1 if off (0=zone 1, 1=zone 2, etc) |
zoneCount | integer | No | the number of zones available for this sprinkler |
zoneNames | list of string | No | list of zone names, starting at zone 1 through zone [zoneCount ] - you must include zoneCount strings in the list |
zoneMaxDurations | list of integer | No | list of zone durations in minutes, starting at zone 1 through zone [zoneCount ] - you must include zoneCount integers in the list |
zoneScheduledDurations | list of integer | No | list of currently active zone durations in minutes if a schedule is running (empty list if no schedule is running), starts at zone 1 through zone [zoneCount ] - you must include zoneCount integers in the list |
Commands (indigo.sprinkler.*)
Next Zone
Parameters |
Pause Schedule
indigo.sprinkler.pause(123)
Parameters |
Previous Zone
Parameters |
Resume Schedule
indigo.sprinkler.resume(123)
Parameters |
Run Schedule
Run a sprinkler schedule.
Parameters |
schedule | Yes | list of integer | list of integers representing the number of minutes to run for each zone - the list must have [zoneCount ] elements, with 0 for any zone that shouldn’t run |
Stop Schedule
indigo.sprinkler.stop(123)
Parameters |
Turn On Zone
Turn on a specific zone.
indigo.sprinkler.turnOnZone(123, index=2)
Parameters |
index | Yes | integer | 0-based index of the zone to turn on |
# run schedule
| -- AppleScript doesn't support directly running a schedule, so
-- then execute that.
-- run schedule
with properties ¬
end if
set zone durations of ¬
to [10, 15, 8, 0, 0, 0, 0, 0]
execute group actionGroupName
ThermostatDevice
Thermostats have a wide variety of capabilities that we’ve tried to boil down to some specifics. They can have multiple temperature and humidity sensors, they generally have a fan mode, an HVAC mode (heating, cooling, etc) and associated setpoints. Note:some thermostats don’t support getting the following values: coolIsOn
, fanIsOn
, and heatIsOn
- for those thermostats those properties will always be False.
coolIsOn | boolean | No | is the cooling system (compressor) currently running |
coolSetpoint | float | No | current cool setpoint value |
fanMode | kFanMode | No | the operating mode for the fan attached to the thermostat |
fanIsOn | boolean | No | is the fan currently running |
heatIsOn | boolean | No | is the heater currently running |
heatSetpoint | float | No | current heat setpoint value |
humidities | list of float | No | a list of floating point values representing the current values of all humidity sensors connected to the thermostat |
humiditySensorCount | integer | No | number of humidity sensors this thermostat supports |
hvacMode | kHvacMode | No | the operating mode for the HVAC system attached to the thermostat |
temperatureSensorCount | integer | No | number of temperature sensors this thermostat supports |
temperatures | list of float | No | a list of floating point values representing the current values of all temperature sensors connected to the thermostat |
Fan Mode Enumeration
indigo.kFanMode |
HVAC Mode Enumeration
indigo.kHvacMode |
Decrease Cool Setpoint
Parameters |
value | Yes | integer | number of degrees to decrease the cool setpoint |
Decrease Heat Setpoint
Parameters |
Increase Cool Setpoint
Parameters |
Increase Heat Setpoint
Parameters |
Set Cool Setpoint
Parameters |
Set Fan Mode
Adjust the fan mode.
Parameters |
Set Heat Setpoint
Parameters |
Set HVAC Mode
Adjust the HVAC mode.
indigo.thermostat.setHvacMode(123, value=indigo.kHvacMode.HeatCoolOn)
Parameters |
# set the heat setpoint to 78
| -- increase the cool setpoint by 5 degrees
