Both sides previous revision Previous revision Next revision | Previous revision | ||
indigo_5_documentation:folder_class [2011/05/30 04:03] jay [Examples] |
indigo_5_documentation:folder_class [2019/01/26 00:10] (current) |
Line 1: | Line 1: | ||
+ | ====== Folders ====== | ||
+ | The folder class represents a folder in the various Indigo user interfaces (Mac client, Indigo Touch, web, etc.). | ||
+ | ==== Class Properties ==== | ||
+ | ^Property ^ Type ^Description ^ | ||
+ | |//''id''//| integer |the unique id of the folder, assigned on creation by IndigoServer| | ||
+ | |//''name''//| string |the name of the folder - no two folders in the same namespace (i.e. //''indigo.devices''//) can have the same name| | ||
+ | |//''remoteDisplay''//| boolean |should this folder be displayed in remote clients (IWS, Indigo Touch, etc)| | ||
+ | ==== Commands (indigo.*.folder.*) ==== | ||
+ | The commands to manipulate folders are within the object lists defined in the IOM Overview page (indigo.devices.folder.*, indigo.variables.folder.*, etc). | ||
+ | === Create === | ||
+ | Create a folder. This method returns a **copy** of the newly created folder. | ||
+ | ^ Command Syntax Examples ^ | ||
+ | |<code>indigo.variables.folder.create("Folder Name Here")</code>| | ||
+ | ^ Parameters ^^^^ | ||
+ | ^ Parameter ^ Required ^ Type ^ Description ^ | ||
+ | |//''name''//| Yes | string |the name of the folder| | ||
+ | === Delete === | ||
+ | Delete the specified folder. | ||
+ | |<code>indigo.devices.folder.delete(123, deleteAllChildren=True)</code>| | ||
+ | |direct parameter| Yes | integer |id or instance of the folder to delete| | ||
+ | |//''deleteAllChildren''//| No | boolean |a boolean to specify whether all objects contained in the folder should be deleted as well - defaults to //''False''//| | ||
+ | === Duplicate === | ||
+ | Duplicate the specified folder. This method returns a copy of the new folder. | ||
+ | |<code>indigo.controlPages.folder.duplicate(123, duplicateName="New Name")</code>| | ||
+ | |direct parameter| Yes | integer |id or instance of the folder to duplicate| | ||
+ | |//''duplicateName''//| No | string |name for the newly duplicated folder| | ||
+ | === Set Remote Display === | ||
+ | Use this command to set the remote display flag for the folder. | ||
+ | |<code>indigo.devices.folder.displayInRemoteUI(123, value=True)</code>| | ||
+ | |<code>indigo.schedules.folder.displayInRemoteUI(123, value=False)</code>| | ||
+ | |direct parameter| Yes | integer |id or instance of the folder| | ||
+ | |//''value''//| Yes | boolean |True to display the folder on remote user interfaces or False to hide it| | ||
+ | ==== Examples ==== | ||
+ | Since folders aren't available in AppleScript, we're only providing Python examples here. | ||
+ | <code># create a new variable folder | ||
+ | newFolder = indigo.variables.folder.create("My New Variable Folder") | ||
+ | # test to see if a folder exists by Name | ||
+ | if ("My New Variable Folder" in indigo.variables.folders): | ||
+ | # should execute this because we just created it | ||
+ | indigo.server.log("folder named 'My New Variable Folder' exists") | ||
+ | # test to see if a folder exists by ID | ||
+ | if (newFolder.id in indigo.variables.folders): | ||
+ | indigo.server.log("folder id " + newFolder.id + " exists") | ||
+ | # set the remote display flag on the folder immediately | ||
+ | indigo.variables.folder.displayInRemoteUI(newFolder, value=False) | ||
+ | # a ValueError exception with the text "NameNotUniqueError" is thrown if you try to | ||
+ | # create a folder with a name that already exists | ||
+ | try: | ||
+ | indigo.variables.folder.create("My New Variable Folder") | ||
+ | except ValueError, e: | ||
+ | if str(e) == "NameNotUniqueError": | ||
+ | # should execute this because it's a dup name | ||
+ | indigo.server.log("folder named 'My New Variable Folder' already exists") | ||
+ | else: | ||
+ | indigo.server.log("Some other error") | ||
+ | # NOTE - at this point, newFolder.remoteDisplay is still true (default for new folders) | ||
+ | # because we're still working with a copy. Refresh it to get it updated: | ||
+ | newFolder.refreshFromServer() | ||
+ | # change the name of a folder | ||
+ | newFolder.name="My Variable Folder" | ||
+ | newFolder.replaceOnServer() | ||
+ | # duplicate the folder | ||
+ | indigo.variables.folder.duplicate(newFolder, duplicateName="My Duplicate Folder") | ||
+ | # delete a folder | ||
+ | indigo.variables.folder.delete(newFolder) | ||
+ | #test to see if a folder doesn't exist using name | ||
+ | if ("My New Variable Folder" not in indigo.variables.folders): | ||
+ | # should execute this because we just deleted it | ||
+ | indigo.server.log("folder named 'My New Variable Folder' does not exist on the server") | ||
+ | # test to see if a folder doesn't exist using ID (was deleted perhaps) | ||
+ | if (newFolder.id not in indigo.variables.folders): | ||
+ | indigo.server.log("folder id " + newFolder.id + " does not exist on the server") | ||
+ | </code> |
