Getting Started Guide
Indigo is a powerful home control server that integrates an assortment of popular INSTEON and X10 hardware devices to provide control of your home. Depending on your needs and budget, you can create a simple system that controls only a couple of lights or you can automate your entire home.
We recommend that you read through all of the help topics under the Getting Started section. These will help you setup Indigo and gain a familiarity with the application.
Indigo comes in two versions: Indigo Pro and Indigo Lite. There are several places in the documentation where you'll see (Pro only feature) - that indicates that the feature/function being described is only available to Indigo Pro users.
Aside from the Indigo 5 documentation page, you should also visit our web site for valuable support resources:
  • Join the online support forum for home automation discussions, software questions, and tips
  • Visit our User Contribution Library to download the latest AppleScripts, plug-ins, and icons/graphics for extending Indigo
  • Mac OS X 10.5.8 (Leopard) or higher
  • Any Macintosh capable of running OS X 10.5.8 or higher (Leopard system requirements) - specifically, the processor must be any Intel, PowerPC G5 or G4 (867 MHz and faster)
  • INSTEON or X10 computer interface: PowerLinc Modem (2412U/2412S/2413U/2413S/), PowerLinc Portable USB Adapter(2448A7), PowerLinc Controller V2 (2414U), PowerLinc Controller (1132CU), PowerLinc USB (1132U), ActiveHome Pro (CM15A), ActiveHome (CM11), or LynX-PLC
  • INSTEON or X10 control modules for lighting, appliance, HVAC, and sprinkler control
If you do not have the required hardware, you can still use the software in offline mode.
Indigo can run as a standalone application on a single Mac or can be run in a client/server mode on two or more Macs. In either case, you must first run the Indigo installer on the main Mac (also referred to as the server Mac) to which the home automation interface hardware (PowerLinc, CM11, etc.) will be connected.
  1. Open the ReadMe.html file for any late breaking information about Indigo or the installation process.
  2. Optionally open and read the Indigo User Manual.pdf file and save or print for later reference (it contains the same content as this electronic help).
  3. Double click the Indigo Installer.mpkg icon to start the Indigo installation.
  4. Follow the instructions provided by the installer. On the Installation Type screen, press the Install button (do not use Customize) to install all the Indigo packages (Server, Server Scripts, Drivers, and Client) on your designated hard drive.
  5. You will be asked to restart your Macintosh at the conclusion of the installation. This must be done in order to properly load the home automation interface drivers.
  6. Optionally, you may move the ReadMe.html and Indigo User Manual.pdf files to a location of your choosing on your hard drive.
The Indigo 5 application can be found here:
  /Applications/Indigo 5
  /Library/Application Support/Perceptive Automation/Indigo 5/
Database files are stored in the Database folder in that folder.
Note: this is the Library folder at the top level of your hard drive, not the one in your User folder. Lion and greater hide these folders by default, but if you select the “Go→Go to Folder…” menu item in the Finder and paste in the path above it will open that folder in a Finder window.
Time Machine will do this by default. To recover, just recover that directory and then install Indigo 5 again.
  • Your old Indigo database file will automatically be converted to the new Indigo 5 file format on first launch. You will be prompted to save the new copy of the Indigo database file. The Indigo 5 file format is not compatible with older versions of Indigo. You should not replace or delete your older Indigo 4.x, 3.x, or 2.x database file. Any changes made in Indigo 5 to your database settings will not be available in older versions of Indigo.
    • Scripts: /Library/Application Support/Perceptive Automation/Indigo 4/Scripts/
    • Control Page Images: /Library/Application Support/Perceptive Automation/Indigo 4/IndigoWebServer/images/
    • Web Server Plugins: /Library/Application Support/Perceptive Automation/Indigo 4/IndigoWebServer/plugins/
    • Scripts: /Library/Application Support/Perceptive Automation/Indigo 2/Scripts/
    • Control Page Images: /Library/Application Support/Perceptive Automation/Indigo 2/IndigoWebServer/images/
NOTE: Do not replace the Indigo 5 versions of the files with your Indigo 4, 3, or 2 files. They have been modified to run optimally under Indigo 5.
  • Your old Indigo database file will automatically be converted to the new Indigo 5 file format on first launch. You will be prompted to save the new copy of the Indigo database file. The Indigo 5 file format is not compatible with Indigo 1.x. You should not replace or delete your older Indigo 1.x database file. Any changes made in Indigo 5 to your database settings will not be available in older versions of Indigo.
  • You will need to manually copy any of your custom script files. You only need to move the files from the Indigo 1.x location ([USERHOMEDIRECTORY]/Documents/Indigo User Data/Scripts/) to the new folder specified above if you modified or added new script or script attachment files.
NOTE: Do not replace the Indigo 5 versions of the files with your Indigo 1.x files. They have been modified to run optimally under Indigo 5.
  5. NOTE: It is not necessary to restart your Mac after installing the Indigo Client package only.
  • Install drivers as necessary on the new Mac.
  • Copy this folder over to the new Mac:
  • Install Indigo 5 on the new Mac
NOTE: this is not the Library folder that's in your home directory - it's the one at the top level of your hard drive. The easiest way to get there is to select the “Go→Go To Folder…” menu item in the Finder and paste in this:
To uninstall Indigo, make sure that you have the server and client completely shut down (select “Stop Server” from the “Indigo 5” menu before you quit the Indigo Mac Client). Then, delete the following files:
  • /Library/Application Support/Perceptive Automation/Indigo 5/
  • /Applications/Indigo 5
  • /System/Library/Extensions/IndigoOverrides.kext
  • ~/Library/Preferences/com.perceptiveautomation.indigo-client5.plist
  • ~/Library/Preferences/Indigo 5 Client Prefs.indiPref
  • ~/Library/Preferences/Indigo 5 Client Settings.indiPref
  • ~/Library/LaunchAgents/com.perceptiveautomation.IndigoServer2.plist
The first three directories are at the top level of your hard drive. The last four are in the Library folder that's in the home directory of the account Indigo runs under. In Mac OS X Lion, the Library folder is hidden in the Finder so you'll have to use the “Go to Folder…” menu item in the Finder and type in the path (“~/Library/Preferences”). That will open a Finder window to the Preferences folder. The last three aren't really required to uninstall but they are included for completeness.
Indigo can run as a standalone application on a single Mac or can be run in a client/server mode on two or more Macs. Regardless of which you are doing, the first step after installation is to launch Indigo and configure the local server.
  1. Double click the Indigo 5 application (/Applications/Indigo 5).
  2. If this is the first time to run Indigo 5 on this Mac, then press the Start Local Server… button in the connection status window.
  3. If you want to reconfigure the Indigo Server on a Mac already running Indigo, then select the Indigo 5→Start Local Server… menu item.
If you only have one Mac and do not wish to remotely access Indigo from a Web browser, iPhone, or iPod Touch, then you can choose the Run client/server as single application radio button. This will automatically run the client/server as a single application, avoiding some complexity.
Uploading to the PowerLinc 1132CU or 2414U for operation while your Mac is turned off is supported in both standalone and client/server mode. In standalone mode the built-in Web server will not be started and you will not have remote Web browser access to control Indigo. NOTE: Indigo Server must be running to use Indigo Touch or to access the Indigo Web Server.
Use the Enable anywhere secure access checkbox for secure Web browser access from anywhere. This option requires a subscription to the Reflector service, which handles maintaining the secure connection to Indigo Server automatically.
Use the Enable remote Indigo client access checkbox to allow remote Indigo Clients on other Macs to connect to the Indigo Server (Pro only feature).
Use the Override Indigo server port number: checkbox to change the TCP/IP port number that the Mac OS X client uses to connect to the server (Pro only feature).
Use the Log Device state history to SQLite or PostgreSQL checkbox to efficiently save Indigo Device state changes, Variable value changes, and Event Log messages to a SQLite or PostgreSQL database. Visit the online support forum for installation and configuration instructions (Pro only feature).
If this is the first time you've started the server, you'll be prompted first to click through our Enduser License Agreement (EULA), then you'll see the server registration dialog:
Enter you name and registration code exactly as they appear in your registration email (copy/paste works best) and click OK. The server will continue to start up.
If you purchased a retail disk, you should enter your full first and last name along with the registration code exactly as it appears on the label on the disk sleeve. When you click OK you'll be prompted to register your copy on our website:
While this isn't required, it's highly recommended. If you don't, we won't be able to locate your registration code in the future should you need it again - and you will to get discounted upgrades to major new releases and access to dot releases.
If you desire easy remote Indigo Server access from outside your home, then you may want to subscribe to the Reflector service, which provides secure Indigo Touch and remote Web browser access from anywhere with no network configuration needed. A free trial subscription is available for all Indigo customers.
In order to remotely access the Indigo Server we must enable the ports Indigo Server uses in the system's network firewall. Follow these steps on the Mac running Indigo Server.
  1. Stop the Indigo Server if it is running by choosing the Indigo 5→Stop Server menu item.
  2. Choose the Apple Menu→System Preferences menu item.
  3. Select the Security preference panel.
  4. Select the Firewall tab.
  5. Select the Set access for specific services and applications radio button.
  6. Restart the Indigo Server by choosing the Indigo 5→Start Local Server… menu item and pressing the Start Server button.
  7. Mac OS X will now ask your permission to allow incoming network connections for the application IndigoServer.app and Python.app. Press the Allow button for each.
The Indigo Web Server advertises itself via Bonjour, so Indigo Touch and Safari (by clicking on the bookmarks icon, then selecting Bonjour) will automatically find any local servers. In addition to that, when connecting to a local server for the first time, Indigo Touch will also automatically fetch Reflector settings for that connection so that you'll be able to connect outside your LAN via Edge/3G.
For other browsers to remotely access the Web server, we need to know the network IP address for the Mac running Indigo Server. This address will be used on the remote Mac or Web browser when connecting to the Indigo Server. Follow these steps on the Mac running Indigo Server.
  1. Choose the Apple Menu→System Preferences menu item.
  2. Select the Sharing preference panel.
  3. If File Sharing is not turned on, then temporarily enable it.
  4. Note the URL shown at the bottom of the window:
    afp://xxx.xxx.xxx.xxx/
  5. The IP address is the number portion of the URL (ex: 192.168.1.23).
  6. If you do not want File Sharing on, then turn it off. You only turned it on to make the IP address visible.
  7. Close the System Preferences window.
You now have the IP address for the Mac running Indigo Server. Depending on your home network setup, this IP address may change periodically, such as when the Indigo Server Mac or router is restarted. If this happens, then you can use the steps above to discover the IP address again, or you can configure a static (not dynamic) IP address for the Mac running Indigo Server.
  1. Double click the Indigo 5 application (inside /Applications/Indigo 5) on the remote Mac.
  2. If this is the first time to run Indigo 5 on this remote Mac, then press the Connect to Remote Server… button in the connection status window.
  3. If you are wanting to connect to a different Indigo Server, then select the Indigo 5→Connect to Remote Server… menu item.
  4. Enter the IP address for the Indigo Server Mac discovered in the section above.
  5. If you overrode the Indigo Server port number (default: 1176) in the Start Local Server dialog on the server Mac, then select the Override default port number checkbox and enter your custom port number.
  6. Press the Connect button.
NOTE: the Indigo Mac Client doesn't use the Reflector service. Connecting an Indigo Mac Client to a server over the internet is a complex topic that is well beyond this document – we suggest you search our online forums for others that have configured this type of access.
Indigo Touch, the iPhone and iPod Touch application from Perceptive Automation, allows the user to view and control Devices, activate Action Groups, view Variables, and access custom Control Pages (Pro only feature). One of the best features of Indigo Touch is it's ability to automatically detect and configure network connections. If your iPhone (or iPod Touch) is connected to your local wireless LAN, then it should automatically discover your server. In Indigo Touch, tap the Settings button. You should see the name of your Database in the list. Tap on it, and it will connect (it will ask for your username/password if you have one set, but it will remember it going forward so you won't have to type it in again).
At this point, Indigo Touch will also query the server to see if you have a Reflector account set up for the server. This makes connecting to your home server via Indigo Touch completely seemless. If you have a reflector set up and running, then Indigo Touch will automatically attempt to connect no matter where you are or how you're connected. If you're local, it will use the local wireless LAN, If you're on a remote wireless LAN, it will attempt to use the reflector account. If you're on you iPhone on EDGE/3G, it will also attempt to connect via your reflector account. This makes Indigo Touch truly location agnostic!
Indigo, when run in client/server mode, will automatically start its built-in Web server on launch. This allows access from remote Macs, PCs, and other internet devices like the iPhone, iPod Touch, Nokia 770 and PepperPad. Any device that can run a modern Web browser (Safari, Firefox, Opera) will work.
 http://192.168.1.23:8176/
Alternatively, if you already have the Indigo Client on a remote Mac connected to the Indigo Server, then you can use Indigo's Go→Browser… menu items to open a new browser page pointing to the built-in Web server.
Indigo can communicate with dozens of different home automation modules, providing control of lighting, lamps, appliances, sprinklers, thermostats and more. Indigo communicates with these INSTEON and X10 compatible modules by using one of several computer interfaces: PowerLinc (2412U, 2412S, 2414U, 1132CU, 1132U), CM11/CM12/HD11/HD12, ActiveHome Pro (CM15A), or LynX-PLC. These interfaces directly communicate with the modules by receiving and sending INSTEON or X10 signals on your power lines.
Different interfaces support different protocols and module features. For example, Indigo can currently upload compiled logic to the PowerLinc 2414U and 1132CU, but not the CM11. We highly recommend INSTEON interfaces and modules over X10 because of their increased signal reliability, performance, and features.
Looking to get started quickly? We've partnered with our online reseller to put together some terrific starter packages.
For specific questions or discussions on hardware, we recommend you join us on our online forum.
Some modules require that you leave Indigo running (and your Mac on) in order to be controlled. Most of the lighting and appliance modules can be controlled after your Mac is turned off when using a PowerLinc 2414U, if you have defined simple Time/Date Actions or Trigger Actions that are upload compatible with the PowerLinc's capabilities.
As an alternative to INSTEON hardware, dozens of X10 modules are also supported by Indigo. Some modules require that you leave Indigo running (and your Mac on) in order to be controlled. Most of the lighting and appliance modules can be controlled after your Mac is turned off when using a PowerLinc 2414U / 1132CU, if you have defined simple Time/Date Actions or Trigger Actions that are upload compatible with the PowerLinc's capabilities.
Dimming may not be accurate for some module types, especially when the PowerLinc is operating in standalone mode (Mac is turned off).
Once you have chosen an INSTEON or X10 interface, see the Connecting the Interfaces section for installation and configuration directions.
RF wireless X10 modules (motion detectors and remote controls) require either a plug-in transceiver (V572AB, TM751, or EZX10RF) or a computer interface that can receive the RF commands, such as: W800USB, W800RF32, MR26, or CM15. There are two different approaches you can use for wireless communication:
  • Use a plug-in transceiver (V572AB, TM751, or EZX10RF) which receives RF signals and then transmits corresponding X10 signals down your power lines to the X10 interface (CM11, LynX-PLC, PowerLinc) connected to Indigo. Using a RF to power line transceiver results in an additional delay between the RF signal and Indigo's reception of the signal. This delay occurs because the transceiver has to broadcast the X10 signal down the power line to the X10 interface before Indigo can receive and trigger actions based on the signal.
  • Use a RF Receiver Interface (W800USB, W800RF32, MR26a, or CM15A) which receives RF signals and then directly sends them to Indigo. When using the RF Interface, the RF signals are sent directly to the computer (no signals need to be transmitted down the power line) resulting in a more responsive control system. Because both the W800RF32 and MR26a are serial devices, you will need a USB serial adapter to connect either one with your computer. If you are using the W800USB, it has USB built-in, but it requires the same FTDI driver as mentioned below for the 2412U/2413U/2448A7H so follow those instructions for installation. The ActiveHome Pro (CM15A) uses USB and does not require a USB serial adapter.
For information about connecting and using the W800USB, W800RF32 or the MR26a RF receiver, see the Connecting X10 RF Interfaces section.
The PowerLinc 2414U/1132CU/1132U and CM15A interfaces can be plugged directly into your computer. The Indigo installer automatically installed the drivers for these interfaces. Make sure you have restarted after the installation process. If you reinstall your OS, then you will need to rerun the Indigo installer for the driver.
The PowerLinc 2412U, 2413U, and 2448A7H interfaces can be plugged directly into your computer as well but require the FTDI Virtual COM Port (VCP) driver to be installed (as does the W800USB mentioned above). You can get the driver installer at FTDI's web site - be sure to get the installer that's appropriate for the architecture of your machine (Intel or PowerPC). If you select PowerLinc 2412U/2412S/2413U/2413S/2448 from the Interface type popup menu in the Preferences dialog (see below), then Indigo will alert you if the driver is not installed on your Mac. If you're using a PowerLinc 2412S/2413S with a separate USB to serial adapter, you can ignore that warning alert.
The other supported interfaces (PowerLinc 2412S/2413S, CM11 / HD11, LynX-PLC) are serial based, and will require a USB serial port adapter. If you are using one of the serial based interfaces, then make sure that the latest drivers for the USB serial adapter are installed on your system. Look on the adapter manufacturer's website for the latest driver downloads.
See the choosing hardware section for details on the supported INSTEON and X10 interfaces and the supported control modules.
Plug the interface directly into an outlet. Do not plug the interface into your computer's power strip because many power strips contain filters that will severely degrade the INSTEON / X10 signal quality being received and transmitted by the interface. Additionally, uninterruptible power supplies (UPSs) can cause signal quality problems. If at all possible plug the interface into a different outlet than used by power strips and UPSs. Signal filters are available to isolate computer power strips and UPSs as well.
Indigo is pre-configured to recognize and use the PowerLinc 2414U/1132CU/1132U interfaces but not the other PowerLinc models. If you are using the PowerLinc 2414U/1132CU/1132U, then you can skip to the Enabling and Disabling Communication section below by choosing the Interface→Connect menu item. Depending on the PowerLinc, Indigo may have to upload information and synchronize with it, which can take a couple of minutes. If you receive an error or are using a different interface model, then manually configure the interface.
  1. Choose Indigo 5→Preferences… menu, then make sure the Interfaces tab is selected.
  3. Choose your Interface type in the popup menu.
  4. Optionally select the Group addresses on transmission checkbox to combine like-command transmissions together. For example A1-On, A3-On, A4-On, would be transmitted as A1, A3, A4, On.
  5. Some interfaces, such as the PowerLinc V2 and LynX-PLC, have additional settings that can be accessed from the Interface Options… button. Generally, these options don't need to be changed unless you're troubleshooting a problem.
Choose the Interfaces→INSTEON/X10 Powerline>Disable menu item to disable/enable the powerline interface.
The process for connecting X10 RF Interfaces is basically the same as for powerline interfaces - you just need to select the correct serial port. The W800USB will require installing the FTDI drivers mentioned above.
Indigo can upload Time/Date and Trigger Actions to the PowerLinc 2414U and 1132CU interfaces, allowing you to have basic home control even when your Mac is not turned on. This is ideal for users that cannot leave their computer on 24/7 or are going out-of-town and want minimal control without a computer.
Indigo has powerful and extensible home control logic and scheduling capabilities. Not all of Indigo's control logic and schedule settings (Trigger Actions and Time/Date) are capable of being run by a standalone interface, such as the PowerLinc. As detailed below, Indigo will describe in the Upload Settings dialog what logic and schedules are compatible to be uploaded to the active interface.
  1. Define the actions that describe the home control schedules and logic you want to upload to the Interface.
  2. Choose the Interfaces→INSTEON/X10 Powerline→Upload Settings… menu item. If the menu item is not enabled, then make sure that you have the correct Interface type selected and enabled in the preferences dialog.
  3. Select the Upload checkboxes for all the actions you want uploaded to the Interface.
Note to the right of the Upload checkbox column there is the Compatibility column. Actions labeled as:
  • good are fully supported by the interface.
  • okay will translate and upload, but the interface does not fully support some of the action’s settings. For example, the PowerLinc 1132CU interface only supports Time/Date actions with sunset and sunrise offsets of +/- 60 minutes. Therefore, any amounts larger (or smaller) than this will be capped to the range the PowerLinc understands. See the Compatibility Details column for detailed information about how each trigger, condition, or action will be translated.
  • poor will not translate at all and will not be uploaded to the interface regardless of the Upload checkbox setting. For example, a Trigger Action that sends an email cannot work at all from within an interface. See the Compatibility Details column for detailed information about why the trigger, condition, or action cannot be uploaded.
  • Press the Upload Actions button to save your changes and immediately upload the actions –OR– press the Save Changes button to exit the dialog and upload your actions the next time you quit the Indigo Client.
Indigo will keep the interface synchronized with your changes by automatically uploading actions whenever you quit the Indigo Client. If you press the Upload Actions button to immediately upload the actions, then Indigo will connect to the interface, upload the compiled actions, and disconnect. TIP: The USB cable must be connected to the Mac and the PowerLinc for this procedure to work correctly.
If you are already connected to the interface, then the Indigo Server itself (not the interface) will continue to control your home automation logic and schedules. Whenever Indigo Server is stopped or told to disconnect from the interface, it will automatically activate the PowerLinc's standalone mode so that your uploaded logic is internally handled by the PowerLinc itself.
TIP: If you want the PowerLinc to operate in standalone mode, you should never disconnect the USB cable from your Mac before the Indigo Server (not the client) shuts down (or disconnects from the interface) - doing so will not allow Indigo to instruct the PowerLinc to begin functioning in standalone mode and none of your schedules or triggers will work correctly.
Indigo has built-in support to both send and scan (Pro only feature) emails. Using this functionality, Indigo can provide remote notification of triggers, such as motion detection or power failures. You can also control Indigo remotely. For example, you could send Indigo an email from your mobile phone to turn on lights or change your home's thermostat temperature.
Typically, ISPs or other email service providers allow multiple email addresses for each customer. We recommend that you create a new email address specifically for Indigo, such as jetsons-house@myisp.com. Using a separate email address for Indigo will eliminate the possibility that Indigo might trigger an action from a personal email not intended for Indigo, and will allow you to use the Delete from server options shown below to reduce mailbox clutter.
To configure email sending
  1. Choose Indigo 5→Preferences… menu item, then make sure the Email tab is selected.
  3. Enter your SMTP user name and password (these may be optional)
To configure email scanning (Pro only feature)
To execute an action based on a scanned email, create an Email Received trigger (Pro only feature).
  • Choose the Indigo 5→Server Preferences… menu item, then make sure the Sunset & Sunrise tab is selected.
The General tab in the Indigo Preferences window allows you to configure what types of update checking Indigo will perform for you, Event Logging options, etc.
For optimal use of Indigo and reliable continuous control of your home, the following operating system settings should be verified. If you are not using Indigo to provide continuous 24 hour/day control or if you are using an interface that supports uploading like the PowerLinc 2414U or 1132CU, then you can ignore the following instructions.
  • /www/perceptive/wiki/data/pages/indigo_5_documentation/getting_started.txt
