myTrigger.replacePluginPropsOnServer(newPropsDict)
rather than try to update them on the local trigger
Unlike Devices, you can't call create()
in the the trigger base class command namespace (indigo.trigger.*
). Rather, each subclass has it's own create()
method that takes the appropriate arguments for that trigger type.
plugin.py
. The easiest one (parallel to the various device events) is triggerStartProcessing(self, trigger)
. This method is also called when the server first starts up your plugin - it will pass all triggers defined to your plugin, one at a time, through this method.indigo.trigger.execute(triggerRef)
method. Note that the execute method will allow you to optionally bypass any conditions - you should NOT do this unless you're providing some kind of override/bypass. Users will clearly want conditions to be taken into account under normal circumstances (that's the default behavior).
You will also need to implement triggerStopProcessing(self,trigger)
so that you can remove disabled/deleted triggers from your watch list. So, the Server isn't really involved at all with the trigger firing (except to execute the trigger when you tell it to) - it only notifies your plugin of events it's supposed to be watching for and your plugin does the rest.
actions | list of Action | Yes | a list of Action objects (action steps in AS) that are executed for this trigger |
globalProps | dictionary | No | an indigo.Dict() representing all name/value pairs associated with this trigger - each plugin will have it's own dictionary (globalProps[pluginId] ) - see About Plugin Properties below for details |
id | integer | No | a unique id of the trigger, assigned on creation by IndigoServer - not available in AppleScript |
Triggers have properties - some are class properties, defined by the class itself. One of the biggest requests we've gotten in the past is some way to add arbitrary properties to an object - so that you could store your own data with the object in the database. And with plugin defined triggers, we needed a place to store the properties that you need to operate the trigger. That's what the pluginProps
and globalProps
is a dictionary of every additional property defined for the trigger - each plugin has it's own dictionary of props in here which are readable by anyone. pluginProps
is a shortcut to get to your plugin's props and are only writable by your plugin.
trigger=indigo.triggers[123] trigger.replacePluginPropsOnServer({"prop1":10,"prop2":True})
defined for the event, those properties are also stored here - so in order to make sure your trigger works correctly you must include those properties as well. If you need to update several properties in your props dict, you can use the update()
method:
trigger=indigo.triggers[123] localPropsCopy = trigger.pluginProps localPropsCopy.update({"prop1":10,"prop2":True}) trigger.replacePluginPropsOnServer(localPropsCopy)
The update()
method will change the properties specified, and add the property if it doesn't exist. Now, you might be wondering - why do the extra localPropsCopy = trigger.pluginProps
trigger=indigo.triggers[123] trigger.pluginProps.update({"prop1":10,"prop2":True}) trigger.replacePluginPropsOnServer(trigger.pluginProps)
Because the trigger object is read-only - when you reference trigger.pluginProps
, it returns a copy rather than returning a reference to the read-only object. So, in effect, you'd be modifying a copy. But, because you aren't saving a reference to that copy, it goes away since the next time you reference trigger.pluginProps
another copy is made.
Command Syntax Examples |
indigo.trigger.delete(123) |
Parameters | |||
direct parameter | Yes | integer | id or instance of the trigger to delete |
Parameters | |||
direct parameter | Yes | integer | id or instance of the trigger to duplicate |
Parameters | |||
direct parameter | Yes | integer | id or instance of the trigger |
duration | No | integer | number of seconds before the trigger is switched back to it’s original state |
Tell the IndigoServer to execute the actions associated with the trigger. If you're plugin implements events, this is the method you'd call when the conditions for your specific event are met. If you're calling it this way, make sure you include the ignoreConditions=False
parameter (or don't include the parameter since False is the default) so that any conditions associated with the trigger (by the user in the UI) are evaluated.
Parameters | |||
Parameters | |||
Parameters | |||
direct parameter | No | integer | id or instance of the trigger |
add examples of updating a trigger's properties
In AppleScript, we didn’t describe them particularly well, but basically we use a 1-based index into an array of possible values. So, for an I/O device, for instance, you’d refer to “binaryInput1”, “binaryInput2”, etc. Or for a sprinkler with multiple zones, it would be “zone1”, “zone2”, etc. In the Python API, we’ve made it easier when referencing these events with the introduction of the stateSelectorIndex. It’s the index into list of available “things” represented by the device’s state.
indigo.kStateChange | ||
Value | Description | Valid for kStateSelector’s |
indigo.kStateSelector | |
BinaryOutputsAll | |
HumidityInput | monitor (one of) the humdity sensor(s) available on the device for =, !=, <, >, and any change - stateSelectorIndex is required to be in the range of available inputs |
KeypadButtonLed | |
indigo.devStateChange.create(name="Trigger Name Here", description="Description Here", folder=1234) |
Parameters | |||
Python | AppleScript |
theTrigger=indigo.devStateChange.create(name="Temp exceeds 80 degrees") theTrigger.deviceId = 738 theTrigger.stateChangeType = indigo.kStateChange.BecomesGreaterThan theTrigger.stateSelector = indigo.kStateSelector.TemperatureInput theTrigger.stateSelectorIndex = 1 theTrigger.stateValue = 80 theTrigger.replaceOnServer() | set theTrigger to make new trigger action with properties {name:"Temp exceeds 80 degrees"} set theTrigger's trigger type to deviceChanged set theTrigger's device name to "Main Thermostat" set theTrigger's state change type to becomesGreaterThan set theTrigger's state selector to "TemperatureInput1" set theTrigger's state value to 80 |
emailFrom | string | Yes | if emailFilter is MatchEmailFields , the value to match against the sender’s address |
emailSubject | string | Yes | if emailFilter is MatchEmailFields , the value to match against the subject line |
indigo.kEmailFilter | |
indigo.emailRcvd.create(name="Trigger Name Here", description="Description Here", folder=1234) |
Parameters | |||
theTrigger=indigo.emailRcvd.create(name="Emails from some@body.com") theTrigger.emailFilter = indigo.kEmailFilter.MatchEmailFields theTrigger.emailFrom = "some@body.com" theTrigger.replaceOnServer() | set theTrigger to make new trigger action with properties {name:"Emails from some@body.com"} set theTrigger's trigger type to emailReceived set theTrigger's email filter to matchEmailFields set theTrigger's email from to "some@body.com" |
indigo.kInsteonCmd | |
indigo.kDeviceSourceType | |
indigo.insteonCmdRcvd.create(name="Trigger Name Here", description="Description Here", folder=1234) |
Parameters | |||
theTrigger= indigo.insteonCmdRcvd.create(name="KeypadLinc button 1 Any Change") theTrigger.command = indigo.kInsteonCmd.AnyCommand theTrigger.commandSourceType = indigo.kDeviceSourceType.Device theTrigger.deviceId = 43829874 theTrigger.buttonOrGroup = 1 theTrigger.replaceOnServer() | (Can't be created in AppleScript) |
indigo.interfaceFail.create(name="Trigger Name Here", description="Description Here", folder=1234) |
Parameters | |||
theTrigger= indigo.interfaceFail.create(name="Any Interface Failed") | set theTrigger to make new trigger action with properties ¬ {name:"Any Interface Failed", trigger type:interfaceFailure} |
indigo.interfaceInit.create(name="Trigger Name Here", description="Description Here", folder=1234) |
Parameters | |||
theTrigger= indigo.interfaceInit.create(name="Any Interface Initialized") | set theTrigger to make new trigger action with properties ¬ {name:"Any Interface Initialized", trigger type:interfaceInitialized} |
indigo.pluginEvent.create(name="Trigger Name Here", description="Description Here", folder=1234), pluginId="com.mycompany.myplugin", pluginTypeId="myEvent", props={"propA":"value","propB":"value"} |
Parameters | |||
indigo.powerFailure.create(name="Trigger Name Here", description="Description Here", folder=1234) |
Parameters | |||
theTrigger= indigo.powerFailure.create(name="Any Interface Detected Power Failure") | set theTrigger to make new trigger action with properties ¬ {name:"Any Interface Detected Power Failure", trigger type:powerFailure} |
indigo.serverStartup.create(name="Trigger Name Here", description="Description Here", folder=1234) |
Parameters | |||
theTrigger= indigo.serverStartup.create(name="Startup") | set theTrigger to make new trigger action with properties ¬ {name:"Startup", trigger type:startup} |
AvButton | kX10AvButton | if command = AvButtonPressed, the A/V button to monitor |
indigo.kX10Cmd | |
indigo.kX10AvButton | |
Value | Value |
0 | Left |
1 | Menu |
2 | Mute |
3 | Pause |
4 | PC |
5 | Play |
6 | Power |
7 | Recall |
8 | Record |
9 | Return |
AB | Rewind |
ChannelDown | Right |
ChannelUp | Stop |
Display | Title |
Down | Up |
Enter | VolumeDown |
Exit | VolumeUp |
Forward |
indigo.x10CmdRcvd.create(name="Trigger Name Here", description="Description Here", folder=1234) |
Parameters | |||
indigo.kVarChange | |
indigo.varValueChange.create(name="Trigger Name Here", description="Description Here", folder=1234) |
Parameters | |||
theTrigger=indigo.varValueChange.create(name="Var Changed to True") theTrigger.variableChangeType = indigo.kVarChange.BecomesEqual theTrigger.variableId = 9283749872 theTrigger.variableValue = "True" theTrigger.replaceOnServer() | set theTrigger to make new trigger action with properties {name:"Var Changed to True"} set theTrigger's trigger type to variableChanged set theTrigger's variable change type to varBecomesEqual set theTrigger's variable name to "SomeVarWhoseIdIs9283749872" set theTrigger's variable value to "True" |
