Variables
value | string | the value of the variable |
Class Method
The Variable class has a special method, getValue(TYPE, default=VALUE)
, that you can call which will retrieve the variable value as the specified Python class. There are a couple of advantages to using this method: first, it won't throw an exception but will always return a value; second, the Indigo server will do the conversion in the exact same way that it does type conversions when using variables in triggers and conditions. You can also optionally specify a default value if the value can't be successfully converted into the specified type. Here's a list of the valid types you can specify and what the default is if not specified:
Type Literal | Type Returned | Default |
bool | Boolean | True will be returned if the value is one of these: “true”, “on”, “yes”, and “1”. False will be returned if the value is one of these: “false”, “off”, “no”, and “0”. If no default value is specified and the value can't be successfully converted, the method will return False. |
int | Integer | An integer object will be returned if the value is an integer number or a float/decimal. In the latter case, the number will be rounded to the nearest integer. If no default value is specified and the value can't be converted, the method will return 0 |
float | Float | A float object will be returned if the value is a float/decimal or an integer. If no default value is specified and the value can't be converted, the method will return 0.0 |
Remember that accessing the value
property of a variable object (var.value
) will return a string object so you don't need a conversion for that.
Class Method Examples
# Get a variable
# Getting the boolean value
# Getting the integer value
# Getting the float value
Commands (indigo.variable.*)
Command Syntax Examples |
Parameters |
Delete the specified folder.
indigo.variable.delete(123)
Parameters |
direct parameter | Yes | integer | id or instance of the variable to delete |
Parameters |
direct parameter | Yes | integer | id or instance of the variable to duplicate |
Parameters |
direct parameter | Yes | integer | id or instance of the variable |
Parameters |
Update Value
Parameters |
Python | AppleScript |
# Create a new variable
# changing name property
newVar.name = "goodName"
newVar.replaceOnServer()
newVar.name = "goodName2"
| -- Create a new variable
-- Update value
set value of newVar to "asleep789"
-- Changing name property
set name of newVar to "goodName"
set newVar to variable "goodName" -- when the name changes, you have to get a fresh reference
-- Changing name and values properties
set name of newVar to "goodName2"
set newVar to variable "goodName2" -- when the name changes, you have to get a fresh reference
set value of newVar to "searchingForWaldo"
delete variable "goodName2"
# You can't get a variable using it's ID in AppleScript
set someVar to variable named "MyVarName"
