X10 Commands (indigo.x10.*)
Send Address
 indigo.x10.sendAddress("A1")
direct parameter Yes string X10 address
suppressLogging No boolean
Send Brighten
delta Yes integer the amount to brighten by relative to the current brightness - valid values from 1 to 100
suppressLogging No boolean a boolean indicating if entries in the event log should be suppressed (default is False)
updateStatesOnly No boolean use if you only want Indigo's internal device state representation to be updated - no actual X10 commands will be sent (default is False)
Send Dim
delta Yes integer the amount to dim by relative to the current brightness - valid values from 1 to 100
Send Extended
command Yes integer the comand to send
data Yes integer the data to send
Send Hail Request
Send Hail Reply
Send On
indigo.x10.sendOn("A1")
Send Off
indigo.x10.sendOff("A1")
Send Status Response On
Send Status Response Off
indigo_5_documentation/x10_specific_commands.txt · Last modified: 2019/01/26 00:10 (external edit)
