| Parameters |
| direct parameter | Yes | integer or string | either the scene number or the scene name - we encourage numbers since they won't change and the scene names can. |
sendCleanUps | No | boolean | true if cleanup messages should be sent to each device in the scene after the scene command - this will have the PowerLinc send each device a message to make sure it received the command. You might want to stop cleanup messages from being sent because it involves adding a lot of INSTEON traffic and might affect performance (particularly if a group has a lot of responders). But, of course, disabling it may reduce reliability of some modules receiving the scene command so it's usually best to ignore this setting. (default is True) |
suppressLogging | No | boolean | true if entries in the event log should be suppressed (default is False) |
updateStatesOnly | No | boolean | use if you only want Indigo's internal device state representation to be updated - no actual INSTEON command will be sent on RF or the power line (default is False) |
| Parameters |
| Parameters |
| Parameters |
| Parameters |
| direct parameter | Yes | string | the target INSTEON address as a hexadecimal string. |
waitUntilAck | No | boolean | true if the caller wants to wait for the result. (default is True) |
| Parameters |
cmdBytes | Yes | list | a list of 2 integer bytes that represent the command to be sent. |
waitForStandardReply | No | boolean | true if the caller wants to wait for a follow-up direct standard reply. (default is False) |
waitForExtendedReply | No | boolean | true if the caller wants to wait for a follow-up direct extended reply. (default is False) |
if reply.cmdSuccess:
indigo.server.log(" backlight brightness: %d" % (reply.replyBytes[10],))
indigo.server.log(" button states bitmap: 0x%02X" % (reply.replyBytes[12],))
setKeypadLedBrightness = [
0x2E, 0x00,
0x00, # unused
0x07, # change LED backlight brightness
0x11, # brightness between 0x11 and 0x7F
| Parameters |
cmdBytes | Yes | list | a list of 2 to 16 integer bytes that represent the command to be sent. |
calcCrc | No | boolean | automatically calculate 8 bit CRC byte for message (used by i2CS firmware). (default is True) |
calc16bitCrc | No | boolean | automatically calculate 16 bit CRC byte for message (used by specific modules). (default is False) |
| Parameters |
