apiVersion | string | No | API v1.7+ only: the currently connected Indigo Server plugin API version as a string (ex: “1.7”) |
/* |portNum| integer | No |the port number of the currently connected Indigo Server */
/* |connectionGood| boolean | No |true if the connection to the Indigo Server is currently good| */
| Parameters |
| direct parameter | No | datetime.date | a datetime.date object representing the day to calculate the sunrise time for |
| Parameters |
| Parameters |
Get Latitude and Longitude
lat = latLong[0]
long = latLong[1]
| Parameters |
| Parameters |
for posixPath in ports:
print(posixPath)
print(uiName)
# iterate through both
print(posixPath)
print(uiName)
indigo.server.getTime()
No Parameters
| Parameters |
| direct parameter | Yes | string | this is the text that’s written to the log |
isError | No | boolean | if True, it will show up in red in the event log - default is False - if no type is included, the name of the plugin will automatically be used with “ Error” appended |
| Parameters |
| Parameters |
