Indigo INSTEON Link Management
The primary place that you'll manage links between devices is in the Manage INSTEON Device Links dialog. Select Manage INSTEON Device Links from Interfaces→INSTEON/X10 Power Line, and the dialog will popup:
  1. Choose Manage INSTEON Device Links… from the Interface menu.
Lastly, to have Indigo write all of your link changes to the remote modules, press the Sync Now button to have Indigo immediately write all changed links to the remote modules. Or, press the Close (Sync Later) button to close the link editor window and write the changes to the modules at a later time. When you are ready to write the changes to the remote modules, select Start Sync INSTEON Device Links… from the Interfaces→INSTEON/X10 Power Line menu, and then press the press the Sync Changes Only button.
Defining the Scene
  1. Choose Manage INSTEON PowerLinc Links… from the Interfaces→INSTEON/X10 Power Line menu.
Lastly, have Indigo write all of your link changes to both the PowerLinc and the remote modules by pressing the Sync Now button to have Indigo immediately write all changed links to the PowerLinc and remote modules. Or, press the Close (Sync Later) button to close the link editor window and write the changes to the modules at a later time. When you are ready to write the changes to the PowerLinc and remote modules select Start Sync INSTEON Device Links… from the Interfaces→INSTEON/X10 Power Line menu, and then press the press the Sync Changes Only button.
Executing the Scene
  3. Select Execute INSTEON Scene from the action Type popup item.
    • Group On will command all of the responder modules to their scene-specific brightness using their scene-specific ramp rate duration, if any.
Make sure all devices are properly wired or plugged in. Select Start Sync INSTEON Device Links… from the Interface menu. Press the Sync All Devices button. Watch the Event Log window to see when the synchronization process is complete. The batch synchronization process can be canceled at any time.
Select Stop Sync INSTEON Device Links from the Interface menu. Watch the Event Log window to see when the synchronization process is canceled.
PowerLinc Replacement
If your PowerLinc is ever replaced, then you must re-sync all of your devices. This will ensure that all devices have their internal links updated to reflect the new PowerLinc's INSTEON address.
indigo_6_documentation/insteon_link_management.txt · Last modified: 2019/01/26 00:10 (external edit)
