Indigo has a long history of extensibility - AppleScript Attachment scripts were available from the start. Later, the Indigo Web Server was added along with the IWS plugin and the ability to add custom images.
With Indigo 5.0, we wanted to add a new server plugin API that would allow 3rd party developers to more natively add devices, triggers, and actions to Indigo. This new server API would allow users and 3rd party vendors to implement their own functionality in Python with full access to all the objects and events that Indigo understands (referred to as the Indigo Object Model, or IOM). Finally, users wouldn’t have to wait for us to add support for, say, the Global Caché IR devices, the THUM devices from Practical Design, etc. Someone with sufficient skills could implement support for those devices, have them integrated into the Indigo UI as first-class citizens. No strange variable state hacks, fake X10 devices, etc. - these new devices are actually recognized as real devices in Indigo.
What’s more, we wanted to ensure that Python programmers have complete access to everything that AppleScript scripts have access to. While AppleScript is a good language for a lot of things (and we aren’t dropping support for it) we believe that using a more modern, standard, capable, and platform agnostic scripting language is much better for our users in the long run.
To deliver this additional functionality, we've introduced a new concept: the Indigo plugin bundle. First, let’s look at the new Application Support folder structure.
Indigo has always supported customization by the user via various folders in the main Indigo directory located here:
/Library/Application Support/Perceptive Automation/Indigo 4
Located inside this folder were several sub-folders where users could put various scripts, web plugins and images. In Indigo 6 (and Indigo 5), we changed the folder structure such that it looks like this:
in this location:
/Library/Application Support/Perceptive Automation/Indigo 6
Notice are the two new folders: Plugins
and Plugins (Disabled)
. These two folders are where the new plugin bundles are stored (see the next section for details). Plugins that are enabled from the UI are located in the Plugins
folder.
One of the biggest problems with extending Indigo was that there were pieces/parts all over the Application Support
folder. As the developer of a solution, you often had to tell people to put various parts of your solution in various places, which of course has a huge margin for user error. To address that problem, we’ve created a new bundle type, the Indigo plugin bundle (.indigoPlugin
), which has a very specific structure:
. It’s moved around and treated as a single file, and all the user has to do to install your solution is to drag the plugin file (bundle) to the Plugins
folder.
. All other files/folders are inside that folder. This is the standard Mac OS bundle construction, so we decided to follow the pattern.
So, why did we go to the trouble of using the bundle format when there's just a file and a couple of folders? Because in future versions, we're going to add capabilities to the plugin bundle (AppleScript Attachments, AppleScript background scripts, shared images, IWS plugins, etc).
Editing a plist file isn’t difficult, but it’s much easier using the Property List Editor
application that Apple ships with the Xcode tools. However, it is just a text XML file that looks like this:
<?xml version="1.0" encoding="UTF-8"?> <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <dict> <key>PluginVersion</key> <string>1.0</string> <key>ServerApiVersion</key> <string>1.0.0</string> <key>CFBundleDisplayName</key> <string>Example Indigo Plugin</string> <key>CFBundleName</key> <string>Example</string> <key>CFBundleIdentifier</key> <string>com.yourdomain.plugin</string> <key>CFBundleVersion</key> <string>1.0.0</string> <key>CFBundleURLTypes</key> <array> <dict> <key>CFBundleURLName</key> <string>http://www.yourdomain.com/plugin/</string> </dict> </array> </dict> </plist>
In Property List Editor
, it looks like this:
PluginVersion
- this is the version number for your plugin - it’s shown to the user in the UI and will help you when supporting your plugin users. This key is required and should only contain numerical characters and periods (0-9 and .). For example, “1.0.5.2” is valid, but “1.0.5b2” is not.ServerApiVersion
- this is the version of the server plugin API as defined by us - for Indigo 6.0, it is 1.9. While we hope to keep API changes to a minimum, it’s prudent to version the server API used. This key is only required if your plugin implements a server plugin.CFBundleDisplayName
) - this is a standard Mac OS X key, and its value represents the name of your plugin. It’s used in a bunch of places in the UI, so make sure that it appropriately identifies your plugin. This key is required.CFBundleName
) - this is another standard Mac OS X key, and it's a name that should be less than 16 characters long and be suitable for displaying in menu items with various strings appended (i.e. “ShortName Device Controls”). If it's not provided we'll use the bundle display name instead.CFBundleIdentifier
) - this is another standard Mac OS X key, and it represents a unique string that represents your plugin. This is used for namespacing where necessary in the code, so it is critical that it is unique. The standard reverse DNS naming scheme is what should be used, although if you aren’t a company you’ll need to figure something out (maybe your blog, etc.). You should limit your bundle id to standard alphanumerics as special/extended characters may cause problems. You should not use the com.perceptiveautomation.*
) - another standard Mac OS X key, and it represents the layout of the bundle. This is controlled by us, and for Indigo 6.0 it will be 1.0.0. This key is required.CFBundleURLTypes
) - you must specify one URL that represents a web page where your user can get support. Your plugin will have a menu item called “About [PLUGIN NAME]” - when the user selects this menu item, the default browser will open to this URL. Note - this can be a forum topic in the “User Contributions” section of our user forums if you don’t have any other place to host the support page. This key is required.We want the user experience to be very similar for plugins, at least until it comes to configuration and use of the plugin, so you should be careful to get the Info.plist correct.
You can drop Python scripts and AppleScripts into this folder and they will show up in your plugin's sub-menu on the new “Plugins” menu. When the user selects the menu item, the script is executed. This is a really simple way of giving your plugin some visible UI. In Indigo 4, if you had loose scripts in the “Scripts” folder, they showed up under the “Scripts” menu item in the Indigo Mac Client. This is no longer the case - if you want scripts to show up in a menu somewhere, you'll need to create a plugin bundle with the scripts you want in the “Menu Items” folder. You don't need to implement a Server Plugin to do this - only have a valid Info.plist file and a Menu Items folder with your scripts.
An important note here: Indigo uses Python v2.6. Python 2.6 was first included in Mac OS X 10.6, which is Indigo's minimum Mac OS requirement. Some newer versions of Mac OS X include Python 2.7 or newer, but for consistency Indigo always executes using Python 2.6 (which is also included in newer Mac OS X versions).
The IOM is used for two similar purposes: scripting Indigo and building Server Plugins. They aren’t mutually exclusive, but they serve different needs. For instance, you may just want to write an embedded Python script action vs building a full Server Plugin. Likewise, you may be interested in building a Server Plugin that doesn’t actually create any new device types, but simply adds events, actions, and menus to Indigo. This is fundamentally different from how AppleScript works with the IndigoServer.
Embedded AppleScripts have an issue: they are required to run on the main thread of the server application. So if an embedded script got hung up, it would hang up the server as well. Not so with Python scripts - they always run in a separate thread (and are killed if they take longer than 10 seconds to execute) so they are somewhat safer. Obviously, if you have a script that takes a long time to run or makes network or other potentially long-running calls, putting it in a script file (where it will execute it it's on special process) is a better idea.
More specifically, the IOM is presented to your plugin as a module, indigo
, Action
, Device
, type
, defaultValue
id
's can contain letters, numbers, and other ASCII charactersid
's cannot start with a number or punctuation characterid
's cannot start with the letters xml (or XML, or Xml, etc)id
's cannot contain spaces
, Events
, Actions
, and the PluginConfig
file.
attribute is required for every field and must be unique within the dialog - it’s used to establish enabled and visible bindings between fields and more importantly it’s the key used in the dictionary to get the values when you get messages from the dialog (discussed more later).
attribute. The value
element and a List
elements. Each Option
element must have a value
attribute and that attribute is what is what will be passed back to your plugin when the dialog is validated; it may not contain comma characters. The text inside the Option
As with menu
The indigo.devices
class specifies that the list will contain Indigo devices. If you don’t specify a filter, all devices defined by the user in Indigo will be returned. You can supply two filters if and only if one is an interface filter (see the first two in the list below). The filters are ANDed together, so one interface filter and one device type filter are the only combinations that will result in a non-empty list.
Class: indigo.devices |
The indigo.triggers
Class: indigo.triggers |
Using the indigo.schedules
and indigo.controlPages
def myListGenerator(self, filter="", valuesDict=None, typeId="", targetId=0): # From the example above, filter = “stuff” # You can pass anything you want in the filter for any purpose # Create an array where each entry is a list - the first item is # the value attribute and last is the display string that will # show up in the control. All parameters are read-only. myArray = [(“option1”, ”First Option”),(“option2”,”Second Option”)] return myArray
Note: both parameters should be strings. Specifically, items with None
as the value (first item) will be skipped.
The valuesDict
The typeId
, Network Socket
, or Network RFC-2217
<Field id="exampleLabel" type="label" <Label>This is where you can put your label text. If need be it'll wrap. </Label> </Field>
Aside from the standard Label
The process flow is this:
<CallbackMethod>
element.
XML for a device like this:
method.
action | validateActionConfigUi(self, valuesDict, typeId, deviceId) | typeId - action type specified in the type attribute deviceId - the unique device ID for the device the user selected for the action if you specify a deviceFilter for your action valuesDict - the dictionary of values currently specified in the dialog |
False
, to indicate that validation faileddef validateEventConfigUi(self, valuesDict, typeId, eventId): # Do your validation logic here errorDict = indigo.Dict() errorDict["someKey"] = "The value of this field must be from 1 to 10" errorDict[“showAlertText”] = “Some very descriptive message to your user that will help them solve the validation problem.” valuesDict["someOtherKey"] = someNewValue return (False, valuesDict, errorDict)
, Events
, and Actions
/Library/Application Support/Perceptive Automation/Indigo 6/Preferences/Plugins/
in the Info.plist
type | Attribute | Yes | This must be one of: relay , dimmer , thermostat , sensor , speedcontrol , or custom . We’ll discuss each below. |
The custom
, String
, List
(enumeration), Boolean
defined in the <Device>
As you can see, your <Event>
element as well - the trigger events dialog now has a help button on it and if one of your events is selected clicking on the help button will take your user to the specified URL. If you don’t specify one then the default help page for all trigger events will show. You can specify an Action to be a separator in your action list so that when they're displayed in the UI there is a visual separation. Simply insert an Event defined like this between two other Event elements:
<Event id="sep1"/>
elements:
need to add some Python examples of how to notify the server that one of these events has occurred
As with <Event>
, your <Action>
element as well - the actions dialog now has a help button on it and if one of your actions is selected clicking on the help button will take your user to the specified URL. If you don’t specify one then the default help page for all trigger events will show. You can specify an Action to be a separator in your action list so that when they're displayed in the UI there is a visual separation. Simply insert an Action defined like this between two other Action elements:
<Action id="sep1"/>
elements:
deviceFilter | Attribute | No | If present a popup list of devices that match the specified device filter will be shown in the UI. Many actions may not need any configuration beyond a device selection so we've enabled you to specify that a device must be selected and passed to the action's CallbackMethod . This will avoid the necessity to create a ConfigUI element with just a device popup. |
uiPath | Attribute | No | Added in API v1.4. You can specify where in the menu hierarchy your action will be placed. By default, Indigo will create a submenu at the bottom of the Actions list and put your actions there. If you specify “DeviceActions”, Indigo will create a submenu on the Device Actions menu and put your actions there. If you specify “NotificationActions”, Indigo will insert your action n the Notification Actions menu without a submenu (be sure to name your action appropriately so that it's clear what it does). |
%%v:12345%%
into their string where 12345
%%d:12345:someStateId%%
In API v1.x
General Plugin Methods | ||
You'll most likely use the |
Note: |
You must call |
Device Specific Methods | ||
deviceCreated(self, dev) | Deprecated in 1.4 | This method was deprecated in v1.4 of the API. It will continue to be called internally, but you'll find the device passed to it not fully created in most circumstances. Use deviceStartComm() instead. |
Trigger Specific Methods | ||
Name | Required | Notes |
and <Actions>
debugLog(self, msg) | msg - the string to insert into the event log | None | If, at any point in your plugin, you set self.debug = True , then any time debugLog is called the string will get inserted into Indigo's event log. If self.debug = False (the default) any call to debugLog does nothing. |
errorLog(self, msg) | msg - the string to insert into the event log | None | If you want an error to show up in the event log (in red text), use this log method rather than indigo.server.log() . |
should discuss the plugin flow for several types of plugins: with devices, events, actions - and plugins that use runConcurrentThread and plugins that start up threads, etc., so that it'll be easier to try and envision how to approach thinking about a plugin.
Discuss the prefs and prefs file (cached and written only periodically or when the plugin quits)
PySerial v2.5 - just “import serial” at the top of your script. PySerial allows your plugins/scripts to access any serial ports on your Mac. The EasyDAQ plugin uses PySerial for it's serial communication so you may find it useful to look at the code for that plugin for examples.
py-appscript v1.0.0 - “import appscript” at the top of your script. Appscript allows you to use apple events to control other applications. Apple events are what AppleScript uses - py-appscript uses the same underlying events. The syntax is obviously Python but it requires a little getting used to. The Airfoil plugin uses py-appscript so you may find it useful to look at the code for that plugin for examples.
simplejson v2.2.1 - simplejson is included in Python v2.6 and higher - but since we're using 2.5 we've included it in the install. Just “import simplejson”.
