Table of Contents
Indigo Scripting Tutorial
Talking to the Indigo Server
Example Code Snippets
Device Examples
indigo.device.duplicate("office desk lamp", duplicateName="office desk lamp2")
indigo.device.turnOn("office desk lamp", duration=2, delay=4)
Turn off all devices:
indigo.device.allOff()
indigo.devices.len()
if hasattr(lamp, 'onState'):
	isOn = lamp.onState
from datetime import datetime
lamp = indigo.devices[91776575] # "Hallway light"
        indigo.device.turnOn(91776575)
Access a custom device state
# get the device
Variable Examples
Getting a variable object and using it's value:
myVar = indigo.variables[123]
if myVar.value == "true":
Duplicating a variable:
import urllib, urllib2
myUnicodeString = u"éçø"
myInteger = 1
myFloat = 1.0
import simplejson as json
myNewDictionary["myList"]
Custom Python classes that you create can implement the __unicode__(self) method. Take this simple example:
class myCustomClass:
  def __init__(self):
	  self.a=1
	  self.b=2
  def __unicode__(self):
    return outputString
cl = myCustomClass()
Date and Time Examples
Get the current server time:
indigo.server.getTime()
import datetime
Action Group Examples
Log Examples
Log to the Indigo Event Log window all of the attributes/properties of the device "office desk lamp":
indigo.server.log(lamp.name + ": \n" + str(lamp))
print(logList)
Folder Examples
except ValueError, e:
		myFolder = None
if lamp.folderId != 0:
	lampsFolder = None
Miscellaneous Examples
Sending emails
# Simple Example
If you already have a Terminal shell running, you can launch it directly. The file path to the IPH executable is a bit deep, so create an alias to it inside your .bashrc (or .bash_profile) file by copying/pasting this into the Terminal (you only need to do this once!):
echo "alias indigohost='/Library/Application\ Support/Perceptive\ Automation/Indigo\ 6/IndigoPluginHost.app/Contents/MacOS/IndigoPluginHost'" >> ~/.bashrc
Next, close the Terminal window and open a new one to load the shortcut alias to the IPH executable. To start the IPH in interactive mode we pass the -i flag to it inside the Terminal:
indigohost -i
As shown, the IPH will automatically connect to the IndigoServer running on the same Mac and will show the server's version information. Additionally, you'll notice that Indigo Server logs the connection of the interactive shell plugin.
Connecting Remotely over SSH
ssh username@indigo_mac_ipaddr -t "/Library/Application\ Support/Perceptive\ Automation/Indigo\ 6/IndigoPluginHost.app/Contents/MacOS/IndigoPluginHost" -i
What Else Can it Do?
indigohost -e 'return indigo.devices["office lamplinc"].brightness'
indigohost -e '
Caveat: Each call creates a new IPH (indigohost) process which must establish a connection to the Indigo Server. Although this is relatively fast, calling it multiple times a second is not recommended.
Executing Indigo Python Files
indigohost -x /SomeFolder/indigo_script.py'
Executing AppleScript
Often times, you may find yourself wanting to execute an AppleScript from Python. You want to send some parameters to the AppleScript and you want to get results back in some format. There's a pretty straight-forward way to do this. First, let's take a look at a simple AppleScript that implements a run handler to capture command line arguments:
on run args
	# the args variable is a simple AppleScript list that you can iterate, etc.
	# do all your AppleScripty stuff here, but save any Indigo stuff for the Python script
	tell application "JSON Helper"
		set theRecord to {parameterCount:length of args, theList:args}
		return make JSON from theRecord
	end tell
end run
This script accepts any number of arguments. It creates an AppleScript record with two entries: parameterCount is the number of arguments passed to the script and theList is just the list of arguments. We then use the excellent (and free) JSON Helper application (available in the Mac app store) to return a JSON string that represents the record.
Next, we implement a simple Python script that will run the AppleScript with some number of arguments, get the JSON returned from it and create a native Python dictionary (which is similar to an AppleScript record):
import subprocess
import json
command_args = ['/usr/bin/osascript', '/path/to/applescript.scpt']
command_args.append("first param")
command_args.append("second param")
result = subprocess.Popen(command_args, stdout=subprocess.PIPE).communicate()[0]
reply_dict = json.loads(result)
# do your Indigo specific stuff here - execute commands, update variables, etc.
indigo.variable.updateValue(12345, reply_dict["theList"][0])
This simple script imports the subprocess and json modules and it creates a list of arguments to send to the subprocess.Popen method. The first two parameters are the command, which in this case is the osascript command that comes with Mac OS X, and the full path to the AppleScript you want to execute. Next, we can just append as many arguments as we want to command_args. Each of these will be accessible in the AppleScript args variable inside the run handler as shown above in the example AppleScript.
Next, we call the Popen method with command_args, set the standard output to a pipe so that we can receive the output in our script, call the communicate method which will actually run the script, and get the first value returned from that command (it's a list, the first value is the complete output of the script).
The result variable at this point is the JSON created by the AppleScript, which looks something like this:
  "theList": [
    "first param",
    "second param"
  "parameterCount": 2
The last thing we want to do is create a native Python dictionary from the JSON string returned by the AppleScript - that's what the json.loads method does.
This is a great pattern for calling AppleScripts from Python, and may help alleviate some of the pain of the Mac OS X “application isn't running” bug (error -600).
Shared Classes and Methods in Python Files (Python Attachments or Modules)
In Indigo, if you want to write AppleScript handlers that are shared by any script that Indigo executes, you can just put an AppleScript full of handlers in the /Library/Application Support/Perceptive Automation/Indigo 6/Scripts/Attachments folder. You can do the same thing with Python using a built-in mechanism that Mac OS X supports for Python. There is a folder in the Library folder at the top level of your boot disk that is very similar to the Attachments folder:
/Library/Python/2.6/site-packages
Any Python files in this directory that define methods and/or classes will be loaded by the Python interpreter whenever it's loaded (note that it's the Library directory at the top level of your boot disk, not the one in your user folder). These are often referred to a modules. So, you can create files of handlers you want to share between all Python scripts. If you add/change something in that directory while the Indigo Server is running, you'll need to tell the server to reload - select the Plugins→Reload Libraries and Attachments menu item and Indigo will restart the Python interpreter (which will cause your library to be reloaded).
Files here can also import the entire IOM - IF the script that's actually running is started by Indigo. Here's a simple shell that you can use that will safely import the IOM and will show a specific error when used from a Python script that's not started by Indigo:
indigo_attachments.py
    import indigo
except ImportError:
    print "Attachments can only be used from within Indigo"
    raise ImportError
def log(message, label=None):
import indigo_attachments
MyMac:testdir jay$ python2.6 testHandlerCall.py
  File "/Users/USERNAME/Library/Python/2.6/site-packages/indigo_attachments.py", line 14, in <module>
    raise ImportError
ImportError
Scripting Indigo Plugins
pluginDisplayName The name displayed to users in the clients
pluginId The ID of the plugin (same as was passed to the getPlugin() method above)
pluginSupportURL The URL supplied by the plugin that points to it's user documentation
pluginVersion The version number specified by the plugin
isEnabled()
This method will return True if the plugin is enabled (running), False otherwise
executeAction(actionId, deviceId, props)
This is the method that actually executes the action. actionId is the unique action id. deviceId is the id of the device that the action on which the action will perform (if it requires a device). props is a dictionary of properties that the action needs to process correctly. See the plugin's documentation for a description of what you need to pass in to execute actions.
restart(waitUntilDone=True)
This method will restart the plugin if it's already running. Pass the optional parameter waitUntilDone=False if you don't want to block while the plugin restarts (waitUntilDone defaults to True if it's no parameters are passed). If you're a plugin developer and you want to restart the plugin from within itself you should pass that parameter.
iTunes Toggle Play State
if itunesPlugin.isEnabled():
iTunes Set Volume to 50
FIXME Add examples for these:
  • refreshing objects
  • replacing objects
  • enabling/disabling objects
  • sprinkler control
indigo_6_documentation/plugin_scripting_tutorial.txt · Last modified: 2017/07/13 23:50 by jay
