key_value_list = [
Protocol Enumeration
| indigo.kProtocol |
Value | Description |
State Image Sel Enumeration
API v1.18+ only:
| indigo.kStateImageSel |
dev=indigo.devices[123]
<State id="playStatus">
<State id="sep1">
<State id="playlist">
<ValueType>String</ValueType>
<State id="album">
<State id="artist">
<State id="track">
<State id="volume">
<State id="shuffle">
# to update the volume state
# to update the track name
# to update the album name
# to update the artist name
# to update the playStatus
Commands (indigo.device.*)
All Off
indigo.device.allOff()
| Parameters |
indigo.kAllDeviceSel |
Beep (API v1.11+ only)
indigo.device.beep(123)
| Parameters |
Create a device. You can create devices that are defined by your plugin, in other plugins, and X10 devices (
you can't currently add INSTEON devices because they need to perform some action to actually make the device function). You use this method to create ALL device types - it will return a device of the correct class to you based on the arguments. It can be considered the “device” factory method.
address='F8',
name='Device Name Here',
folder=1234)
| Parameters |
indigo.device.delete(123)
| Parameters |
| Parameters |
Enable/Disable
| Parameters |
Get Group List
| Parameters |
| Parameters |
ID : 1280166770 (integer)
ID : 106487666 (integer)
| Parameters |
Ping Device (API v1.16+ only)
if result["Success"]:
| Parameters |
| Parameters |
| Parameters |
| Parameters |
Status Request
| Parameters |
Toggle
indigo.device.toggle(123)
| Parameters |
Turn Off
indigo.device.turnOff(123)
| Parameters |
Turn On
indigo.device.turnOn(123)
| Parameters |
Unlock (API v2.0+ only)
indigo.device.unlock(123)
| Parameters |
Lock (API v2.0+ only)
indigo.device.lock(123)
| Parameters |
Here’s a side by site comparison of using various device properties in Python and AppleScript (Deprecated in a future version of Indigo 7):
| Python | AppleScript (Deprecated in a future version of Indigo 7) |
# Creating a device
name="Office Lamp",
address="F7",
| -- Creating a device
address:"F7",¬
# Getting a device
| -- Getting a device
| -- Logging a message if it’s an X10 device
log "device is an X10 device"
end if
if (myDevice.remoteDisplay):
| -- Logging a message if it’s showing in Indigo Touch
end if
| -- Folder ID is not available in AppleScript
| -- Turning off all devices (dimmer and relay)
all off
all lights off "A"
-- AppleScript
Commands (indigo.dimmer.*)
All Lights Off
indigo.dimmer.allLightsOff()
| Parameters |
All Lights On
indigo.dimmer.allLightsOn()
| Parameters |
Brighten
indigo.dimmer.brighten(123)
| Parameters |
Dim
indigo.dimmer.dim(123)
| Parameters |
Set Brightness
| Parameters |
Set LED State
| Parameters |
Set On State
Here’s a side by site comparison of dimmer properties in Python and AppleScript (Deprecated in a future version of Indigo 7):
# Getting a device
| -- Getting a device
(myDevice.onState)):
| -- Set a device’s brightness to 75 if it’s currently
end if
| -- Brighten a light by 25% after 10 minutes
end if
myDevice.folderId
# OR
Commands (indigo.iodevice.*)
Set Binary Output
| Parameters |
index=1,
value=False)
| -- If binary input 3 is false, set binary output 1
-- to false
of device "EZIO8SA"
of device "EZIO8SA"
"EZIO8SA" to theBinaryOutputs
end if
Commands (indigo.sensor.*)
Set On State
| Parameters |
Commands (indigo.relay.*)
Set LED State
| Parameters |
# Toggle the device
| -- Toggle the device
toggle device “Office Lamp”
Decrease Speed Index
Decreases the speed index.
| Parameters |
Increase Speed Index
Increases the speed index.
| Parameters |
Set Speed Index
| Parameters |
Set Speed Level
| Parameters |
activeZone | integer | No | 1.0 | the 1-based index of the active zone (None=all zones off, 1=zone 1, 2=zone 2, …). Note this property has undergone changes in name (previously called activeZoneIndex) as well as semantics (previously the index being 0-based). As of API v1.12 (Indigo 7.0.3) the property is final and stable. |
Commands (indigo.sprinkler.*)
Next Zone
| Parameters |
Pause Schedule
indigo.sprinkler.pause(123)
| Parameters |
Previous Zone
| Parameters |
Resume Schedule
indigo.sprinkler.resume(123)
| Parameters |
Run Schedule
Run a sprinkler schedule.
| Parameters |
Stop Schedule
indigo.sprinkler.stop(123)
| Parameters |
Set Active Zone
| Parameters |
# run schedule
| -- AppleScript doesn't support directly running a schedule, so
-- then execute that.
-- run schedule
with properties ¬
end if
set zone durations of ¬
to [10, 15, 8, 0, 0, 0, 0, 0]
execute group actionGroupName
Fan Mode Enumeration
indigo.kFanMode |
HVAC Mode Enumeration
indigo.kHvacMode |
Decrease Cool Setpoint
| Parameters |
Decrease Heat Setpoint
| Parameters |
Increase Cool Setpoint
| Parameters |
Increase Heat Setpoint
| Parameters |
Set Cool Setpoint
| Parameters |
Set Fan Mode
Adjust the fan mode.
| Parameters |
Set Heat Setpoint
| Parameters |
Set HVAC Mode
Adjust the HVAC mode.
| Parameters |
# set the heat setpoint to 78
| -- increase the cool setpoint by 5 degrees
