Indigo Server Plugin Tutorial
Note most of the code examples below are calling methods on the object self. In this context, self is meant to be the Plugin instance as defined inside the plugin.py file. To execute the sample code outside Plugin instance methods use the indigo.activePlugin object instead.
Important: For simplicity some of the samples below specify objects based on name (“office desk lamp”). However, the preferred lookup mechanism is to use the object's ID which can be retrieved by control-clicking on the object name in Indigo's Main Window. By using the ID you ensure the object will be found even if its name is changed.
Plugin task Plugin that illustrates an approach
Parsing XML from an IP source NOAA Weather, WeatherSnoop
Interacting with an IMAP mail server iCal Alarm Processor
Creating custom devices with states Simple: NOAA Weather, WeatherSnoop - Complex: EasyDAQ, iTunes
Creating custom actions Growl, Action Collection
Each of these plugins is installed by default with Indigo 7 - in the /Library/Application Support/Perceptive Automation/Indigo 7/Plugins (Disabled)/ folder. To see the various XML and python source files, just right-click on it in the Finder and select Show Package Contents.
  • Per plugin prefs file is automatically managed (created, loaded, updated).
  • Plugin can also insert other values into its pluginPrefs space (not just values shown in the plugin's config UI).
  • Example adding new plugin metadata to the Device “den fixture”:
    dev = indigo.devices["den fixture"]
    newProps = dev.pluginProps
    newProps["onCycles"] = 5
    newProps["moreData1"] = "abc"
    newProps["moreData2"] = True
  • Example reading the plugin specific property onCycles from the Device “den fixture”:
  • Example incrementing by 1 the plugin specific property onCycles for the Device “den fixture”:
    newProps["onCycles"] += 1
  • States defined in Devices.xml are automatically shown in the Trigger Event Device State Changed options when that plugin device type is selected, and are automatically shown in the Control Page editor when a control is created inspecting that plugin device.
  • Plugins should subclass deviceStartComm and deviceStopComm to start/stop any hardware communication (normally via a new per-device thread):
  • Calls to deviceStartComm and deviceStopComm are automatically managed by the Indigo Server and Indigo Plugin Host. When a plugin first connects all enabled device instances owned by the plugin will receive deviceStartComm calls. Likewise, deviceStartComm is called when a new plugin device is created or duplicated. deviceStopComm is called whenever a plugin is disabled, deleted, or when the plugin is shutting down. Therefore, these two functions should be the primary bottlenecks for starting/stopping device hardware or network connections.
FIXME Give examples of using indigo.devices.subscribeToChanges() and plugin subclasses of functions: deviceDeleted, deviceUpdated.
  • /www/perceptive/wiki/data/pages/indigo_7.3_documentation/plugin_extending_tutorial.txt
