Growl Plugin
Notification Types
Notification Action
When you're ready to send a notification, you just add a “Notification” action and adjust its options via the action config dialog:
- Type - this specifies the notification type (see above to configure those)
- Title† - this is the title of the notification - typically shown at the top of the notification window
- Description† - this is the description of the notification, typically shown in the main content area of the notification
- Priority - that's the Growl-defined priority (not used by most Growl themes)
- Sticky - that indicates whether the notification will require the user to manually close it or if Growl will close it automatically after some period of time
† - the title and description fields may contain substitution markup. So, as you can see from the example above, we're substituting the value of variable ID 867446802 in the title and variable ID 264884531 in the description. See Substitutions for more information.
Scripting Support
Action specific properties
Notify
Action id: notify
Properties for scripting:
type | the string key of the notification type, must be one of: 'notification1', 'notification2', 'notification3', 'notification4', 'notification5', 'notification6', 'notification7', 'notification7' and must be enabled in the preferences (see preferences above) |
title | the title of the growl notification |
descString | the full text of the notification |
priority | the optional number priority for the notification: -2 (very low) through 2 (emergency) - defaults to 0 (normal priority) |
sticky | optional boolean that will cause the notification to stick (not automatically disappear) - defaults to False |
growlPlugin = indigo.server.getPlugin("com.perceptiveautomation.indigoplugin.growl")
if growlPlugin.isEnabled():
growlPlugin.executeAction("notify", props={'type':"notification1", 'title':"Growl Title", 'descString':"Description of Growl Notification", 'priority':0, 'sticky':False})
Support and Troubleshooting
