iTunes Plugin for Indigo
The old iTunes AppleScripts are included by the installer for backwards compatibility.
iTunes Device Dialog Image
Configure Device Dialog Image
This dialog tells you what to do next. You must pair this new device with the iTunes Server that you intend to control. Switch to iTunes - if you're using iTunes 12, you'll see a button with an right arrow in it in the upper left corner of the iTunes window:
iTunes 12 Pair Image
If you're using iTunes 11, you'll see a button titled Remote in the upper right corner next to the iTunes Store button:
iTunes 11 Pair Image
iTunes Outline View Image
Select Indigo Remote Control
iTunes Passkey Prompt Image
iTunes Device States Image
iTunes Actions Menu Image
  • Play - start iTunes playing
  • Pause - pause iTunes
  • Pause iTunes and Say - pause iTunes (if it's running) and speak the supplied text. Restart only if it was paused to begin with.\\iTunes Pause and Say Dialog Image
Play
Action id: play
if itunesPlugin.isEnabled():
Pause
Action id: pause
Toggle Play/Pause
Action id: playPause
Next Track
Action id: nextTrack
Previous Track
Action id: prevTrack
Restart Track
Action id: restartTrack
Pause and Speak Text
Action id: pauseAndSay
Properties for scripting:
Set Volume
Action id: setVolume
Increase Volume
Action id: increaseVolume
Decrease Volume
Action id: decreaseVolume
Set Repeat
Action id: setRepeat
Set Shuffle
Action id: setShuffle
  • /www/perceptive/wiki/data/pages/indigo_7.3_documentation/plugins/itunes.txt
