SQL Logger Plugin
  • Download a PostgreSQL installer. Note there are other installers available elsewhere as well.
  • Add the path to the PostgreSQL binary to your bash profile file. From the Terminal copy/paste:
  • Next, open the System Preferences and choose the PostgreSQL Server icon that was added. You should now be able to start the server. Note the some installers seem to included a Server Manage.app application, but they may not work correctly. However, the panel in the System Preferences does appear to work.
  • From the command line you can now try to connect to the server via:
psql -U postgres
  • Next, select the Plugins→SQL Logger→Configure… menu item, then select PostgreSQL as the database type.
SQL Logger Configuration Image
and
ts brightnesslevel onoffstate
2012-05-16 16:00:32 0 f
2012-05-16 16:01:44 74 t
2012-05-16 16:01:44 29 t
2012-05-16 16:44:46 0 f
2012-05-16 16:45:03 29 t
2012-05-16 16:45:35 0 f
2012-05-16 18:20:09 28 t
2012-05-16 19:01:57 29 t
2012-05-16 19:15:12 38 t
2012-05-16 19:15:13 48 t
ts temperature humidity
2012-05-16 16:00:32 73 85
2012-05-16 16:01:44 74 85
2012-05-16 16:01:44 73 85
2012-05-16 16:44:46 72 86
2012-05-16 16:45:03 71 87
2012-05-16 16:45:35 68 87
2012-05-16 18:20:09 65 88
2012-05-16 19:01:57 67 87
2012-05-16 19:15:12 68 86
2012-05-16 19:15:13 69 86
ts value
2012-05-16 16:00:32 Idle
2012-05-16 16:01:44 Arm Home
2012-05-16 16:01:44 Idle
2012-05-16 16:44:46 Arm Away
PostgreSQL Queries
SQLite Queries
Plugin SQL Logger Event Image
Aug 9, 2012 3:38:10 AM
  • /www/perceptive/wiki/data/pages/indigo_7.3_documentation/plugins/sql_logger.txt
