Timers and Pesters
Timers
Plugin Timers New Timer Image
  1. Select DEVICES (or one of its subfolders) from the Outline View
  2. Click on the New… button
  6. Click Save
Plugin Timers Actions Image
  • Set Timer Start Value - use this action to set the default timer value without actually starting the timer. If the timer is running when it has its start value changed, it will stop running.
Plugin Timers Events Image
  1. Select TRIGGERS (or one of its subfolders) from the Outline View
  6. Click Save
Pesters
Plugin Timers and Pesters Actions Image
Scripting Support
Start Timer
Action id: startTimer
if timerPlugin.isEnabled():
Pause Timer
Action id: pauseTimer
Restart Timer
Action id: restartTimer
Resume Timer
Action id: resumeTimer
Stop Timer
Action id: stopTimer
Action id: setTimerStartValue
Properties for scripting:
  • /www/perceptive/wiki/data/pages/indigo_7.3_documentation/plugins/timersandpesters.txt
