The Indigo Reflector Service
Prism Architecture Image
Reflectors provide:
  • Hassle free setup:
  2. Turn on the Require authentication checkbox and enter a User name and good Password. You will *definitely* want password authentication on since you are about to enable access to the Indigo web server from the Internet.
  1. Shut down the Indigo Server (select Indigo 7.3→Stop Server) but don't quit the Indigo Client
Manual Reset
  5. In the resulting dialog, copy and paste the following: /Library/Application Support/Perceptive Automation/Indigo 7.3/Preferences/
  • /www/perceptive/wiki/data/pages/indigo_7.3_documentation/reflectors.txt
