Getting Started Guide
Welcome to Indigo 7.3!
- Mac OS X 10.7.5 (https://en.wikipedia.org/wiki/Mac_OS_X_Lion) or higher.
- Any Mac capable of running Mac OS X 10.7.5.
Z-Wave
- ON/OFF devices (plug-in modules, switches, and outlets)
- Dimmers (plug-in modules and switches)
- Sensors (contact, magnetic, motion, temperature, etc.)
- Thermostats
- Locks
INSTEON
X10
Other Devices
Other Sources for Help
Installing Indigo
- The Indigo Installer.pkg file - double click this to start the Indigo installation. Follow the instructions provided by the installer. On the Installation Type screen, press the Install button (do not use Customize) to install all the Indigo packages (Server, Server Scripts, Drivers, and Client) on your designated hard drive. Note: you must install and run Indigo from an account on your Mac that has administrator privileges.
The Indigo 7.3 application can be found here:
/Applications/Indigo 7.3.app
By default database files are stored in the Databases
folder in that folder.
Backing Up Indigo
Time Machine will do this by default. To recover, just recover that directory and then run the Indigo 7.3 installer again (which will repair any permission issues that Time Machine may have introduced).
Upgrading from Indigo 7.2
In addition to the automatic upgrade logic described below (for upgrades from Indigo 6 and ealier), the installer moves previously installed control page images and web server plugins to the new install location.
Indigo 7.2→Stop Server
menu item in the Mac client. This will shutdown the Indigo Server regardless of which version is running. - Quit the Mac client via the
Indigo 7.2→Quit Indigo
menu item. - Open the
/Applications
In addition to the automatic upgrade logic described below (for upgrades from Indigo 6 and ealier), the installer is now smarter and moves previously installed control page images and web server plugins to the new instsall location.
Indigo 7→Stop Server
Indigo 7→Quit Indigo
/Applications
After running the Indigo 7 installer, here are a few things you may need to consider:
- Indigo 7 moved to Python 2.7, so if you installed any shared scripts (as outlined here) then you'll need to move them from:
/Library/Python/2.6/site-packages/
to/Library/Python/2.7/site-packages/
- Indigo will automatically copy your old preference file into the new location during the installation.
- Indigo will also copy over any enabled and disabled Plugins from Indigo 6 or 5. If a newer version of a plugin is included in Indigo 7, then it will automatically be installed and used on launch.
- Your old Indigo database file will automatically be converted to the new Indigo 7 file format on first launch. A copy of your database will automatically be made before it is converted, but any changes made in Indigo to your database will not be available in older versions of Indigo.
- Scripts:
/Library/Application Support/Perceptive Automation/Indigo 6/Scripts/
- Control Page Images:
/Library/Application Support/Perceptive Automation/Indigo 6/IndigoWebServer/images/
- Web Server Plugins:
- Scripts:
/Library/Application Support/Perceptive Automation/Indigo 5/Scripts/
/Library/Application Support/Perceptive Automation/Indigo 5/IndigoWebServer/images/
- Scripts:
- Scripts:
NOTE: Do not replace the Indigo 7(.X) versions of any file with your Indigo 6, 5, 4, 3, or 2 files. They have been modified to run optimally under Indigo 7(.X).
Upgrading from Indigo 1.x
- Your old Indigo database file will automatically be converted to the new Indigo 7 file format on first launch. You will be prompted to save the new copy of the Indigo database file. The Indigo 7(.X) file format is not compatible with Indigo 1.x. You should not replace or delete your older Indigo 1.x database file. Any changes made in Indigo 7(.X) to your database settings will not be available in older versions of Indigo.
[~your user home folder]/Documents/Indigo User Data/Scripts/
) to the new folder specified above if you modified or added new script or script attachment files.
NOTE: Do not replace the Indigo 7(.X) versions of any file with your Indigo 1.x files. They have been modified to run optimally under Indigo 7(.X).
Moving an Indigo 7 Installation to another Mac
Indigo 7.3→License Details…
menu item and clicking theDeactivate License
button. Do this while the Indigo Server is still running (do not shutdown the Indigo Server first). - Copy this folder over to the new Mac:
- Install Indigo 7.3 on the new Mac (download and run the installer)
Uninstalling Indigo
To uninstall the Indigo Server and all of its data and configuration files, first deactivate Indigo on your Mac by selecting the Indigo 7.3→License Details…
from the Indigo 7.3
/System/Library/Extensions/IndigoOverrides.kext
~(your user folder)/Library/Preferences/com.perceptiveautomation.indigo-client6.plist
~(your user folder)/Library/Preferences/Indigo 7 Client Prefs.indiPref
~(your user folder)/Library/Preferences/Indigo 7 Client Settings.indiPref
To uninstall older versions but leave 7.3 installed correctly, delete these:
- Indigo 7.2:
/Library/Application Support/Perceptive Automation/Indigo 7.2/
/Applications/Indigo 7.2.app
- Indigo 7.0 and 7.1:
/Applications/Indigo 7.app
/Applications/Indigo 6.app
Starting Indigo Server
- Double click the
Indigo 7.3
application (/Applications/Indigo 7.3.app
). - If this is the first time to run
Indigo 7
on this Mac, then press theStart Local Server…
button in the connection status window. - If you want to reconfigure the Indigo Server on a Mac already running Indigo, then select the
Indigo 7.3→Start Local Server…
menu item.
If you only have one Mac and do not wish to remotely access Indigo from a Web browser, iPhone, or iPod Touch, then you can choose the Run client/server as single application
radio button. This will automatically run the client/server as a single application. This requires that the Indigo UI always be running on your Mac - when you quit the Indigo 7.3 Client application (Indigo 7.3→Quit
) all Indigo event processing (triggers, schedules, scripts, etc.) will cease processing. This is not our recommended configuration.
Running in Client/Server Mode
Choose the Start and connect to Indigo Server
Use the Allow remote access
checkbox to enable remote access from other Macs and Web browsers.
Use the Enable iPhone, iPod Touch, and remote Web browser access
checkbox to allow Indigo Touch (must be downloaded from the iTunes App Store) and remote Web browser access from other computers. Any modern Web browser (Safari, Firefox, Opera) on any computer that has internet access to your server Mac will be able to control and check the state of your home.
Use the Enable remote RSS feeds
checkbox to turn on the RSS and Atom server feeds, giving you RSS/Atom access to the last modified time stamp of all Indigo Devices.
Use the Require authentication
checkbox to enable password protection for both remote Indigo Clients and Web browser access. It is highly recommended that you enable authentication and assign a strong password.
Use the Enable anywhere secure access
checkbox to allow remote Indigo Clients on other Macs to connect to the Indigo Server.
Use the Log Device state history to SQLite or PostgreSQL
checkbox to efficiently save Indigo Device state changes, Variable value changes, and Event Log messages to a SQLite or PostgreSQL database. Visit the online support forum for installation and configuration instructions.
Starting the Server
Press the Start Server
button, or the Restart Server
button.
Remote Indigo Access
Modifying Firewall Settings
- Double click the
Indigo 7.3
application (inside/Applications/Indigo 7.3.app
) on the remote Mac. - If this is the first time to run
Indigo 7
on this remote Mac, then press theConnect to Remote Server…
button in the connection status window. - If you are wanting to connect to a different Indigo Server, then select the
Indigo 7→Connect to Remote Server…
menu item. - Enter the
IP address
for the Indigo Server Mac discovered in the section above. - If you overrode the Indigo Server port number (default:
1176
) in the Start Local Server dialog on the server Mac, then select theOverride default port number
checkbox and enter your custom port number. - Press the
Connect
button.
on the Settings
http://192.168.1.23:8176/
Managing Plugins
Installing Plugins
- Make sure that the plugin is supported by Indigo 7.2 (look for the Requires field).
- Click the
Download Latest Release
button, which will download the plugin. - Most plugins will show the plugin directly as the above image. If it does, double click it and proceed to step 8 below.
.indigoPlugin
. Double-click that file. - You will be switched to the Indigo Client app, and you'll a dialog window which asks you if you want to install and enable the plugin
- Click the
Install and Enable
button. - Done!
Incompatible Plugins
Note if you see the error alert below that the “Plugin is not compatible” then the version of the plugin you installed is too new to run with your Indigo Server version. In this case the best solution is to upgrade your version of Indigo Server.
- Open the Trash folder from the Finder
- Move the previous (older) version of the plugin from the Trash folder to your Desktop.
- Lastly, follow the same instructions as above to re-install the older version of the plugin (Double-click it).
Plugin Configuration
Plugin Menus in Indigo
Main Plugins Menu
- a gray dot means the plugin is disabled
- a green dot with no arrows means the plugin is enabled
- a green dot with a black arrow means the plugin is enabled and there is an update available that will work with your Indigo version
- a green dot with a red arrow means the plugin is enabled and there is an update available but it won't work with your version of Indigo
The Manage Plugins…
The Plugin Store
will open the Scripts folder (where you can install Python libraries) in the Finder (see Shared Classes and Methods in Python Files for details).
The Open Scripting Shell
Individual Plugin Submenu
menu. For instance, here's the BetterEmail plugin submenu when it's enabled:
Enable
to enable the plugin andDisable
to disable the plugin. - the
Reload
menu item will reload the plugin and will only be present if the plugin is enabled. - there may be a couple more menus if you have the
Enable debugging menus
item selected in the Plugins tab of the Indigo Preferences (and are discussed in that section).
The next section contains:
- the
Configure…
menu item will open a config dialog if the plugin has plugin-specific configuration items (if not or if the plugin is disabled, it will not be present). - the
Show in Plugin Store…
menu item will open the plugin's entry in the Plugin Store in the default browser. If there is an available plugin update that will work on your version of Indigo, the menu title will beDownload New Version…
which will also open the plugin's entry in the Plugin Store in the default browser so you can download the new version, and if there is an incompatible version the menu title will beIncompatible Version Available…
which will drop a sheet showing what version of Indigo is required to run the new plugin version. This menu item will always show, but if it's grayed out it means the plugin isn't from the Plugin Store. - the
About…
menu item will always show the current version of the plugin and will always be enabled.
Other Menus with Plugin Items
You can also enable/disable a plugin and download a new plugin version from the Plugins tab in the Indigo Preferences. You open the config window choosing the Indigo 7→Preferences…
menu item discussed above.
- the
checkbox will add two new menus to the plugin's menus:Reload in Debugger
will reload the plugin and connect to the selected debugger;Reload in Interactive Shell
will open a terminal window with a Python shell that's connected to the plugin so the developer can run commands and inspect arbitrary objects in the running plugin. - the
Use debugger
popup is used to tell Indigo which debugger to start the plugin up when you use the above menu items.
Uninstalling a Plugin
Indigo 7.3→Stop Server
menu item in the Mac client (you can leave the client app running). - Open the following folder in the Finder:
(you can select theGo→Go to Folder…
menu item in the Finder and paste in the path to open a Finder window). In that Finder window you'll see two folders:Plugins
andPlugins (Disabled)
. Depending on whether the plugin is enabled or not will determine which folder it's in. Open the appropriate folder and delete the unwanted plugin. - Switch back to the Indigo 7.3 Mac client and click on the
Start Local Server…
button in theServer Connection Status
dialog.
Configuring Email Settings
Typically, ISPs or other email service providers allow multiple email addresses for each customer. We recommend that you create a new email address specifically for Indigo, such as jetsons-house@myisp.com. Using a separate email address for Indigo will eliminate the possibility that Indigo might trigger an action from a personal email not intended for Indigo, and will allow you to use the Delete from server
options shown below to reduce mailbox clutter.
To configure email sending
- Choose
menu item, then make sure theEmail
tab is selected. - Enter your SMTP server address. You probably don't need to change the SMTP server port, but if your server uses SSL (TLS) security, check that checkbox.
- Enter your SMTP user name and password (these may be optional)
- If you want the recipient of the email to reply to a different email address than the one you're sending from, enter it in the
Reply-to email address
field. Note that some SMTP mail servers are configured to not send emails unless the reply-to address specified matches the email address for the account. If mail sending fails, then make sure that the reply-to email address matches the email address for your account.
To configure email scanning
- Choose
tab is selected. - Enter your POP server address, user (also called account) name, and password.
- Select the
Check email every
checkbox. - Enter the time interval to wait between email scans (default 10 minutes).
- Optionally choose
Delete from server emails that trigger actions
to have Indigo automatically remove any email messages that cause Indigo to trigger an action from your mail server. You should only use this option if Indigo has a dedicated email account. - Optionally choose
Delete from server all emails
to have Indigo automatically remove all email messages from your mail server. You should only use this option if Indigo has a dedicated email account.
To have Indigo send an email, create a Send Email
action.
To execute an action based on a scanned email, create an Email Received
trigger.
- Choose
System Preferences
from theApple
menu. - Select the
Date & Time
icon. - Select the
Time Zone
panel. - If the current
Closet City
location is not near your location, then follow the instructions on the panel to choose your location.
- Choose the
Indigo 7.3→Preferences…
menu item, then make sure theSunset & Sunrise
tab is selected. - Select the
Override system location
checkbox. - Enter your exact
Latitude
andLongitude
coordinates.
You can configure other Indigo settings by opening the preferences dialog (selecting the Indigo 7→Preferences…
tab.
You can have Indigo check for updates immediately by selecting the Indigo 7→Check for Updates…
menu item.
- Choose
System Preferences
from theApple
menu. - Select the
Energy Saver
icon. - Move the
Computer sleep:
slider toNever
. - Uncheck
Put the hard disk(s) to sleep when possible
. - Select the
Start up automatically after a power failure
checkbox.
Where to Go Next
