Connecting an Insteon (or X10 power line) interface to Indigo requires a couple of steps, described below.
For earlier versions of the OS, you can get the driver installer at FTDI's web site - be sure to get the installer that's appropriate for the architecture of your machine (Intel or PowerPC). If you select PowerLinc 2412U/2412S/2413U/2413S/2448 from the Interface type
with a separate USB to serial adapter, you can ignore that warning alert. Note: there are known issues with the FTDI driver and macOS High Sierra and Mojave on some Macs - check out our blog post for details.
Indigo 7→Preferences…
menu, then make sure the Interfaces
tab is selected.Enabled
checkbox next to the INSTEON / X10 Powerline Interface
item.INSTEON/X10 Power Line Interface
line in the table (you can also get to this dialog by selecting the Interfaces→INSTEON/X10 Power Line→Configure…
menu item)Interface type
in the popup menu.Serial port:
popup menu will be enabled and the FTDI driver (see Install the Correct Drivers above) will create a new Serial port:
popup menu item that looks like usbserial-XXXXXXXX
. Select that item. NOTE: you must have the FTDI driver installed already.Serial port:
popup menu will be disabled because these interfaces do not use a virtual serial port driver.Serial port:
popup menu will be enabled and you should choose which serial port adapter name the interface is connected to in the Serial port:
popup menu. NOTE: if no names are listed in the Serial port:
popup menu, then you probably do not have the proper driver installed for your USB serial adapter. Download your adapter's driver from the driver manufacturer's website.Group addresses on transmission
checkbox to combine like-command transmissions together. For example A1-On, A3-On, A4-On, would be transmitted as A1, A3, A4, On.
Choose the Interfaces→INSTEON/X10 Power Line→Disable
(or Enable
menu item. See connecting the Interface above for more details.
To add a new Insteon device:
New…
button at the top of the Home window.Here's the INSTEON device dialog:
The Define and Sync…
dialog:
The Re-Sync Links…
dialog:
The primary place that you'll manage links between devices is in the Manage INSTEON Device Links dialog. Select the Interfaces→INSTEON/X10 Power Line→Manage Device Links
menu item.Show links used by device
popup control.If the module you selected is a controller (RemoteLinc, KeypadLinc, SwitchLinc, etc.), then you can add or edit responders:
New Link to Responder
button. If you want to change the settings (brightness, ramp rate duration, etc.) of an existing responder module in the scene, then select that module's link in the table with the Link to Responder Device
column title.broadcast of button/group number
popup control.cool
and heat
setpoint temperatures.Persistent
checkbox to force this link to automatically be restored whenever either the responder module or controller module is synced. If the modules are ever reset, replaced, or have this link modified, then Indigo will automatically rewrite the original link on the next sync operation.If the module you selected is a responder (LampLinc, Thermostat Adapter, KeypadLinc, SwitchLinc, etc.), then you can add or edit controllers:
New Link to Controller
button. If you want to change the settings (brightness, ramp rate duration, etc.) used by the selected module in a controller's scene, then select the controller module's link in the table with the Link to Controller Device
popup control.cool
and heat
setpoint temperatures via those text boxes.Persistent
button to close the link editor window and write the changes to the modules at a later time. When you are ready to write the changes to the remote modules, select Start Sync Device Links…
button.
action.
Manage PowerLinc Links…
menu.PowerLinc Group/Scene
number to use for the scene. Use 1 if this is your first scene.PowerLinc Group/Scene
name in the edit field (ex: “reading in bed”).Next, create a new link for every responder module in the scene:
button. If you want to change the settings (brightness, ramp rate duration, etc.) of an existing responder module in the scene, then select that module's link in the table in the top-half of the window.responder
popup control.cool
and heat
setpoint temperatures using the text boxes.Persistent
checkbox to force this link to automatically be restored whenever the responder module is synced. If the responder module is ever reset, replaced, or has this link modified, then Indigo will automatically rewrite the original link into the device when it is next synced.
button.
Actions
tab inside the edit window.INSTEON Actions→Execute INSTEON Scene
from the action Type
popup item.Send
will turn off all of the modules immediately, ignoring any ramp rate duration.Scene
popup item.
menu itemInterfaces→Insteon/X10 Power Line→Enable
menu itemInterfaces→Insteon/X10 Power Line→Configure…
menu itemInterface Options…
buttonSync Links
buttonThe last step will take a while, so watch the Event Log window for progress.
submenu contains a collection of miscellaneous INSTEON commands that will help you manage specific aspects of devices as well as do so low-level INSTEON commands not directly supported in the UI:
, Turn Off
, Leave Alone
