NOAA Weather
Plugin Config
Device States
Observation Date/Time- The last time the data was updated by NOAA. This field is in RFC822 Date/Time format (i.e. “Fri, 19 Aug 2011 11:51:00 -0500”) so it can be parsed by other software if needed.Current Condition- The current condition in a word or twoCurrent Condition Icon- The current condition icon - Indigo ships with “NOAA Condition+.png” and it's children, one for each condition that's returned in this field. So, in the control page editor, select this state and “NOAA Condition+.png” and you'll have a nice conditions icon (images provided by NOAA)Visibility- Visibility in milesTemperature °F- Temperature in FahrenheitTemperature °C- Temperature in CelsiusTemperature String- Temperature in a human-readable string (i.e. “98.0 F (36.7 C)”) - this is the state shown in the “State” column for a Weather Station deviceRelative Humidity- The relative humidityDew Point °F- Dew point in FahrenheitDew Point °C- Dew point in CelsiusDew Point String- Dew point in a human-readable stringHeat Index °F- Heat index in FahrenheitHeat Index °C- Heat index in CelsiusHeat Index String- Heat index in a human-readable stringWind Direction- Wind direction description in something close to human-readable formWind Degrees- Wind direction in degreesWind MPH- Wind speed in miles per hourWind Knots- Wind speed in knotsWind String- A description of the wind in human-readable formPressure (inches)- Pressure in inchesPressure (mbar)- Pressure in millibarsLocation- Location in human-readable formLatitude- LatitudeLongitude- Longitude
Scripting Support
Support and Troubleshooting
