SQL Logger Plugin
- Download a PostgreSQL installer. Note there are other installers available elsewhere as well.
- Add the path to the PostgreSQL binary to your bash profile file. From the Terminal copy/paste:
- Next, open the System Preferences and choose the PostgreSQL Server icon that was added. You should now be able to start the server. Note the some installers seem to included a Server Manage.app application, but they may not work correctly. However, the panel in the System Preferences does appear to work.
- From the command line you can now try to connect to the server via:
psql -U postgres
- Next, select the
Plugins→SQL Logger→Configure…menu item, then selectPostgreSQLas the database type.
Logging Options
SQL Logger Configuration Image
Database Table Format
and
| ts | value |
Example Queries
PostgreSQL Queries
SQLite Queries
Events
Aug 9, 2012 3:38:10 AM My Type Error this is an error from a script NOAA Weather Plus Error Error parsing XML from NOAA for device Weather Forecast: not well-formed (invalid token): line 1, column 111
Scripting Support
Support and Troubleshooting
