Triggers
Trigger Base Class
globalProps | dictionary | No | an indigo.Dict() representing all name/value pairs associated with this trigger - each plugin will have its own dictionary (globalProps[pluginId]) - see About Plugin Properties below for details |
Commands (indigo.trigger.*)
indigo.trigger.delete(123) |
| Parameters | |||
| Parameters | |||
Enable/Disable Trigger
| Parameters | |||
duration | No | integer | number of seconds before the trigger is switched back to its original state |
Execute Trigger
| Parameters | |||
| Parameters | |||
| Parameters | |||
add examples of updating a trigger's properties
DeviceStateChangeTrigger
State Change Type Enumeration
| indigo.kStateChange | ||
State Selector Enumeration
| indigo.kStateSelector | |
BinaryOutputsAll | |
HumidityInput | monitor (one of) the humidity sensor(s) available on the device for =, !=, <, >, and any change - stateSelectorIndex is required to be in the range of available inputs |
KeypadButtonLed | |
folder=1234)
| Parameters | |||
EmailReceivedTrigger
emailFrom | string | Yes | if emailFilter is MatchEmailFields, the value to match against the sender’s address |
emailSubject | string | Yes | if emailFilter is MatchEmailFields, the value to match against the subject line |
Email Filter Enumeration
| indigo.kEmailFilter | |
Commands (indigo.emailRcvd.*)
folder=1234)
| Parameters | |||
theTrigger=indigo.emailRcvd.create(name="Emails from [email protected]") theTrigger.emailFilter = indigo.kEmailFilter.MatchEmailFields theTrigger.emailFrom = "[email protected]" theTrigger.replaceOnServer()
InsteonCommandReceivedTrigger
INSTEON Command Enumeration
| indigo.kInsteonCmd | |
folder=1234)
| Parameters | |||
InterfaceFailureTrigger
folder=1234)
| Parameters | |||
InterfaceInitializedTrigger
folder=1234)
| Parameters | |||
PluginEventTrigger
folder=1234),
pluginTypeId="myEvent",
| Parameters | |||
PowerFailureTrigger
folder=1234)
| Parameters | |||
ServerStartupTrigger
folder=1234)
| Parameters | |||
X10CommandReceivedTrigger
X10 Command Enumeration
| indigo.kX10Cmd | |
X10 A/V Button Enumeration
| indigo.kX10AvButton | |
| Value | Value |
0 | Left |
1 | Menu |
2 | Mute |
3 | Pause |
4 | PC |
5 | Play |
6 | Power |
7 | Recall |
8 | Record |
9 | Return |
AB | Rewind |
ChannelDown | Right |
ChannelUp | Stop |
Display | Title |
Down | Up |
Enter | VolumeDown |
Exit | VolumeUp |
Forward | |
folder=1234)
| Parameters | |||
VariableValueChangeTrigger
| indigo.kVarChange | |
folder=1234)
| Parameters | |||
