Class Method Examples
# Get a variable
unicodeValue = var.value
# Getting the boolean value
# Getting the integer value
# Getting the float value
Commands (indigo.variable.*)
| Parameters |
Delete the specified folder.
indigo.variable.delete(123)
| Parameters |
| Parameters |
| Parameters |
ID : 552463741 (integer)
ID : 296710860 (integer)
| Parameters |
| Parameters |
Update Value
| Parameters |
# Create a new variable
# changing name property
newVar.name = "goodName"
newVar.replaceOnServer()
newVar.name = "goodName2"
