apiVersion | string | No | API v1.7+ only: the currently connected Indigo Server plugin API version as a string (ex: “1.7”) |
Calculate Sunrise
Command Syntax Examples |
Parameters |
direct parameter | No | datetime.date | a datetime.date object representing the day to calculate the sunrise time for |
Calculate Sunset
Parameters |
Event Log List
Parameters |
returnAsList | No | boolean | if true a list of dicts is returned containing individual log entry attributes; if false a string containing a textual description of the log lines is returned - the default is false |
lineCount | No | integer | the number of lines to return from the event log starting from newest and going backwards in time - the default is 1500 |
showTimeStamp | No | boolean | indicate whether every line should have it’s timestamp prepended to the log entry - the default is true |
Get Database File Name
Get Database File Path
Get Install Folder Path
Get Latitude and Longitude
lat = latLong[0]
long = latLong[1]
Get Plugin
Parameters |
direct parameter | Yes | string | the id of the plugin to retrieve |
Get Serial Ports
Parameters |
for posixPath in ports:
print(posixPath)
print(uiName)
# iterate through both
print(posixPath)
print(uiName)
Get Time
indigo.server.getTime()
No Parameters
Log
Parameters |
direct parameter | Yes | string | this is the text that’s written to the log |
level | No | integer | API v2.4+ only: the python logging level which determines both the type shown and the text color used. (ex: using “level=logging.WARNING” will show orange text) |
isError | No | boolean | if True , it will show up in red in the event log - default is False - if no type is included, the name of the plugin will automatically be used with “ Error” appended |
Remove All Delayed Actions
Send Email
Parameters |
direct parameter | Yes | string | a semicolon separated string of email addresses |
Speak
Parameters |
direct parameter | Yes | string | the string to speak |
