Indigo 7 provides a Virtual Devices Interface type that provides users with several new device types, each discussed below. If you want to use Virtual Devices, make sure to enable them by selecting the Interfaces→Virtual Devices→Enable
menu item.
DEVICES
dialog.Virtual Devices
from the Type popup menu.With the addition of Z-Wave (and various plugins that define dimmer and relay devices) it has become apparent that we need to provide some way to create technology agnostic groups of devices. You can, of course, control groups of devices through Action Groups, and for most cases that's good enough.
To create a device group, you just create a new device, select Virtual Devices
from the Type
menu, select Device Group
from the model menu, and you'll see the configuration dialog:
To use a device group, just use the standard Control Light/Appliance
action to turn it ON/OFF, and create triggers on the group's ON and OFF state via the Device State Changed
trigger type. Turning a device group on will set all the devices to their respective saved state. You can also update the states of the devices in the group at any time by using the Update Device Group States
action or menu item. That's it!
That's where the Virtual ON/OFF Device
comes in. This device type will allow users create custom devices without the need to build an entire plugin. In fact, the first iteration of this device doesn't even require any programming at all! Virtual devices can be shown in the Indigo UI, the Indigo Web UI, and the Indigo Touch UI as on/off style devices and can be controlled using the normal on/off UI controls.
To create a virtual device, you just create a new device, select Device Collection
from the Type
menu, select Virtual On/Off Device
The first thing you'll select are the action groups to execute when the device is turned on and off. So if you click the Turn On
button or select the Turn Off
action in the Control Light/Appliance action
, for example, the appropriate action group will be executed. These two are the minimum requirements for this type of virtual device.
Note: if you don't enable Supports Status
, your virtual device will always show as being “off” in the UI and triggers that watch for state change will never fire. That may be fine for your particular needs so we made it optional.
