apiVersion string No API v1.7+ only: the currently connected Indigo Server plugin API version as a string (ex: “1.7”)
Calculate Sunrise
Calculate Sunset
Event Log List
showTimeStamp No boolean indicate whether every line should have it’s timestamp prepended to the log entry - the default is true
Get Database File Name
Get Database File Path
Get Install Folder Path
Get Latitude and Longitude
lat = latLong[0]
long = latLong[1]
Get Plugin
Get Serial Ports
for posixPath in ports:
	print(posixPath)
	print(uiName)
# iterate through both
	print(posixPath)
	print(uiName)
Get Time
indigo.server.getTime()
No Parameters
Log
level No integer API v2.4+ only: the python logging level which determines both the type shown and the text color used. (ex: using “level=logging.WARNING” will show orange text)
Remove All Delayed Actions
Send Email
Speak
indigo_7.5_documentation/server_commands.txt · Last modified: 2020/12/04 16:55 (external edit)
