Indigo Mac Client
The Home Window has 4 areas:
  1. Outline View
  2. Item List
  3. Item Detail
  4. Status Bar
To create a new folder, select the main object type in the list then click the plus (+) button at the lower-left corner of the outline view. A new folder will appear and you can just start typing it's new name.
This menu will:
  1. Enable/disable the event.
Plugin devices, regardless of whether they implement one of the built-in device types below or if they are completely custom devices, will also have a Custom States tile that will show all of the device's custom states. This tile is always below the first row of tiles so you may need to scroll or resize the Item Detail area to see it:
Lights/Appliances
color_controls_tile
Speed Controls
Sprinklers
Thermostats
Generic Output Devices
Triggers and Schedules
Control Pages
Click the Clear Window button to clear the log entries. Click on Show Event Logs Folder to open the Logs folder in the Finder. Here you will find one file for each day's events. You can change how many day's worth of event log files are stored by selecting Indigo 7→Preferences… and then selecting the General tab. There, you can enter the number of days of event log files that you want to keep. Indigo Server will delete all files outside of that period of time.
  • About Indigo 7 - this will show the About window which will show what client and server versions you're running and will show your registration code
  • Preferences… - this opens the preferences dialog
  • Email Log… - this option will email some of your event log data to the specified email address. Particularly useful for technical support
  • Indigo 7 Documentation - this will open your browser to the landing page for all Indigo 7 documentation
  • /www/perceptive/wiki/data/pages/indigo_7.5_documentation/ui_tour.txt
