Managing Your Z-Wave® Network
Indigo 7 provides several tools to manage your Z-Wave network. Not only can you create/control/delete devices but you can also manage device associations and scenes. See the Connecting Z-Wave Interfaces section of the Getting Started Guide for details on connecting and configuring your Z-Wave interface.
Tip: if you're having issues with Indigo communicating with some of your Z-Wave devices, look at the position of your Z-Stick or EZController / Z-Troller. If you have it plugged directly into your Mac then the chances are that the signal range is reduced somewhat. Also, if there are any other electronics close to it (external hard drives, etc.) then you may want to try to move the interface around a little. For the Z-Stick, try a USB hub with connectors on the top that allow you to position it vertically. A word of warning: some users have used short USB extension cables successfully but others have found that these sometimes cause communication errors with the Z-Stick.
Z-Wave Dialog Settings Image
  4. Click on the Sync button.
Z-Wave Menu Image
Manage Associations
Send Raw Z-Wave Command
Stop Inclusion / Exclusion
Optimize Z-Wave Network
Reset Z-Wave Interface
  • /www/perceptive/wiki/data/pages/indigo_7_documentation/managing_z-wave_devices.txt
