EasyDAQ Relay Card Plugin
  • USB24MxS (24 relays)
  • USBDIO24 (24 DIO channels)
Easydaq Settings Window Image
Easydaq Action Pagel Window Image
Some actions have additional options available via the Edit… button. For example, the Change Multiple Outputs action allows you to control (turn on, turn off, or toggle) all the outputs with a single, and very fast, action:
Easydaq Action Change Multi Window Image
Easydaq Trigger Device State Change Window Image
Turn On Output
Action id: turnOnOutput
Properties for scripting:
if easyDaqPlugin.isEnabled():
Turn Off Output
Action id: turnOffOutput
Toggle Output
Action id: toggleOutput
All Outputs On
Action id: allOutputsOn
All Outputs Off
Action id: allOutputsOff
Action id: changeMultiple
  • /www/perceptive/wiki/data/pages/indigo_7_documentation/plugins/easydaq_1.txt
