iTunes Plugin for Indigo
The old iTunes AppleScripts are included by the installer for backwards compatibility.
Plugin Config
This dialog tells you what to do next. You must pair this new device with the iTunes Server that you intend to control. Switch to iTunes - if you're using iTunes 11, you'll see a button titled Remote in the upper right corner next to the iTunes Store button:
Select Indigo Remote Control
Device States
Player Status Changed- any change to the play state of iTunesPlayer Status is Playing- iTunes is playingPlayer Status is Paused- iTunes is pausedPlayer Status is Stopped- iTunes is stoppedPlayer Status is Unavailable- iTunes is unavailable - it's probably not runningPlayer Status is Error- this iTunes device has an unknown error - look in the Event Log for details
Current Playlist Name- the current playlist that's selected in iTunesCurrent Album- the current album nameCurrent Artist- the current artist nameCurrent Track- the current track nameCurrent Volume- the current volume level
Repeating Changed- any change in repeat statusRepeating None- iTunes is not repeatingRepeating Song- iTunes is repeating the current songRepeating Playlist- iTunes is repeating the current playlistShuffling- iTunes is shuffling songs
Actions
Play- start iTunes playingPause- pause iTunesToggle Play/Pause- toggle between playing and pausedNext Track- move to the next trackPrevious Track- go back to the previous trackRestart Track- restart the current track
Pause iTunes and Say- pause iTunes (if it's running) and speak the supplied text. Restart only if it was paused to begin with.
Set Volume- set the volume to a specific level (0-100)Increase Volume- increase the volume by a specific amount (0-100)Decrease Volume- decrease the volume by a specific amount (0-100)
Set Repeat- set iTunes to repeat (or not)Set Shuffle- set/unset shuffling
Scripting Support
Action specific properties
Play
Action id: play
if itunesPlugin.isEnabled():
Pause
Action id: pause
Toggle Play/Pause
Action id: playPause
Next Track
Action id: nextTrack
Previous Track
Action id: prevTrack
Restart Track
Action id: restartTrack
Pause and Speak Text
Action id: pauseAndSay
Properties for scripting:
Set Volume
Action id: setVolume
Increase Volume
Action id: increaseVolume
Decrease Volume
Action id: decreaseVolume
Set Repeat
Action id: setRepeat
Set Shuffle
Action id: setShuffle
Support and Troubleshooting
