The Indigo Reflector Service
About Reflectors
Reflectors provide:
- Hassle free setup:
Activating your Reflector
- Choose the
Require authenticationcheckbox and enter a User name and good Password. You will *definitely* want password authentication on since you are about to enable access to the Indigo web server from the Internet. - Turn on the
Enable anywhere secure accesscheckbox. - Press the
Activate Reflectorbutton.
Resetting Your Reflector's Activation
Indigo 7(.2)→Stop Server) but don't quit the Indigo Client - Switch to your browser and log out of your Indigo Account
Start Local Serverbutton
Manual Reset
/Library/Application Support/Perceptive Automation/Indigo 7/Preferences/for Indigo 7.0 and 7.1,/Library/Application Support/Perceptive Automation/Indigo 7.2/Preferences/for Indigo 7.2 - In the resulting Finder window, delete the folder named
Bandwidth Limits
