Triggers
id integer No a unique id of the trigger, assigned on creation by IndigoServer - not available in AppleScript
trigger=indigo.triggers[123]
indigo.trigger.delete(123)
Enable/Disable Trigger
Execute Trigger
In AppleScript (which will be deprecated in Indigo 7.2 and later), we didn’t describe them particularly well, but basically we use a 1-based index into an array of possible values. So, for an I/O device, for instance, you’d refer to “binaryInput1”, “binaryInput2”, etc. Or for a sprinkler with multiple zones, it would be “zone1”, “zone2”, etc. In the Python API, we’ve made it easier when referencing these events with the introduction of the stateSelectorIndex. It’s the index into list of available “things” represented by the device’s state.
State Change Type Enumeration
indigo.kStateChange
AnalogInput
BrightnessLevel
HumidityInput
SensorInput
SetpointCool
SetpointHeat
TemperatureInput
BinaryOutput
HvacCoolerIsOn
HvacFanIsOn
HvacFanModeIsAlwaysOn
HvacFanModeIsAuto
HvacHeaterIsOn
HvacOperationModeIsAuto
HvacOperationModeIsCool
HvacOperationModeIsHeat
HvacOperationModeIsOff
OnOffState
Zone
BrightnessLevel
HumidityInput
SensorInput
SetpointCool
SetpointHeat
TemperatureInput
BrightnessLevel
HumidityInput
SensorInput
SetpointCool
SetpointHeat
TemperatureInput
AnalogInput
BrightnessLevel
HumidityInput
SensorInput
SetpointCool
SetpointHeat
TemperatureInput
BinaryOutput
HvacCoolerIsOn
HvacFanIsOn
HvacFanModeIsAuto
HvacHeaterIsOn
OnOffState
Zone
AnalogInput
AnalogInputsAll
BinaryInput
BinaryInputsAll
BinaryOutput
BinaryOutputsAll
BrightnessLevel
HumidityInput
HumidityInputsAll
HvacCoolerIsOn
HvacFanIsOn
HvacFanMode
HvacFanModeIsAuto
HvacHeaterIsOn
OnOffState
SensorInput
SensorInputsAll
SetpointCool
SetpointHeat
TemperatureInput
TemperatureInputsAll
Zone
State Selector Enumeration
indigo.kStateSelector
Value Description
BinaryOutputsAll
KeypadButtonLedFIXME
    folder=1234)
Python AppleScript (which will be deprecated in Indigo 7.2 and later)
theTrigger.deviceId = 738
theTrigger.stateValue = 80
theTrigger.replaceOnServer()
set theTrigger to make new trigger action with properties {name:"Temp exceeds 80 degrees"}
set theTrigger's trigger type to deviceChanged
set theTrigger's device name to "Main Thermostat"
set theTrigger's state change type to becomesGreaterThan
set theTrigger's state selector to "TemperatureInput1"
set theTrigger's state value to 80
Email Filter Enumeration
indigo.kEmailFilter
Value Description
    folder=1234)
set theTrigger to make new trigger action with properties {name:"Emails from [email protected]"}
set theTrigger's trigger type to emailReceived
set theTrigger's email filter to matchEmailFields
set theTrigger's email from to "[email protected]"
INSTEON Command Enumeration
indigo.kInsteonCmd
Value Description
Dimwhen a dim command begins
indigo.kDeviceSourceType
Value Description
    folder=1234)
Python AppleScript
theTrigger.buttonOrGroup = 1
(Can't be created in AppleScript)
    folder=1234)
set theTrigger to make new trigger action with properties ¬
    {name:"Any Interface Failed", trigger type:interfaceFailure}
    folder=1234)
    {name:"Any Interface Initialized", trigger type:interfaceInitialized}
    folder=1234),
    pluginTypeId="myEvent",
    folder=1234)
    {name:"Any Interface Detected Power Failure", trigger type:powerFailure}
    folder=1234)
    {name:"Startup", trigger type:startup}
X10 Command Enumeration
indigo.kX10Cmd
Value Description
X10 A/V Button Enumeration
indigo.kX10AvButton
Value Value
0 Left
1 Menu
2 Mute
3 Pause
4 PC
5 Play
6 Power
7 Recall
8 Record
9 Return
AB Rewind
ChannelDown Right
ChannelUp Stop
Display Title
Down Up
Enter VolumeDown
Exit VolumeUp
Forward
    folder=1234)
myTrigger.address = "F7"
myTrigger.replaceOnServer()
indigo.kVarChange
Value Description
    folder=1234)
set theTrigger to make new trigger action with properties {name:"Var Changed to True"}
set theTrigger's trigger type to variableChanged
set theTrigger's variable change type to varBecomesEqual
set theTrigger's variable name to "SomeVarWhoseIdIs9283749872"
set theTrigger's variable value to "True"
  • /www/perceptive/wiki/data/pages/indigo_7_documentation/trigger_class.txt
