Send Scene ON
sendCleanUps No boolean true if if cleanup messages should be sent to each device in the scene after the scene command - this will have the PowerLinc send each device a message to make sure it received the command. You might want to stop cleanup messages from being sent because it involves adding a lot of INSTEON traffic and might effect performance (particularly if a group has a lot of responders). But, of course, disabling it may reduce reliability of some modules receiving the scene command so it's usually best to ignore this setting. (default is True)
suppressLogging No boolean true if if entries in the event log should be suppressed (default is False)
Send Scene OFF
Send Scene Fast ON
Send Scene Fast OFF
Send Status Request
direct parameter Yes string the target INSTEON address as a hexidecimal string.
waitUntilAck No boolean true if the caller wants to wait for the result. (default is True)
Send Raw
cmdBytes Yes list a list of 2 integer bytes that represent the command to be sent.
waitForStandardReply No boolean true if the caller wants to wait for a follow-up direct standard reply. (default is False)
waitForExtendedReply No boolean true if the caller wants to wait for a follow-up direct extended reply. (default is False)
Send Raw Extended
if reply.cmdSuccess:
	indigo.server.log("     backlight brightness: %d" % (reply.replyBytes[10],))
	indigo.server.log("     button states bitmap: 0x%02X" % (reply.replyBytes[12],))
setKeypadLedBrightness = [
	0x2E, 0x00,
	0x00,			# unused
	0x07,			# change LED backlight brightness
	0x11,			# brightness between 0x11 and 0x7F
cmdBytes Yes list a list of 2 to 16 integer bytes that represent the command to be sent.
calcCrc No boolean automatically calculate 8 bit CRC byte for message (used by i2CS firmware). (default is True)
calc16bitCrc No boolean automatically calculate 16 bit CRC byte for message (used by specific modules). (default is False)
Send PowerLinc SET Button Press Message
indigo_7_documentation/insteon_specific_commands.txt · Last modified: 2019/01/26 00:10 (external edit)
